08-11-2019, 12:13 PM | #1 |
Drives: 2019 ZL1 1LE Join Date: Jul 2019
Let's play "What's wrong with my brand new car!?"
I'll try to keep this concise, but it is a head scratcher for me.
I have a 19 SS 1LE I bought new in April. I entered a competition at a car show and part of it was a dyno. It made 342 RWHP on a DynoJet. They did not have a WBO2 on it. It was a fast paced event so the dyno operator didn't have time to mess with it or talk to me, but said he was surprised how low it was. I was expecting at least 380, maybe more. I chalked it up to them not knowing what they were doing or maybe their mobile dyno was F'd. But still, a glimmer of doubt was there. So I took it to another local shop (TPIS) and had it run again and it still made ~340, but this time we had AFR, and it is pig rich at ~10.5:1 throughout the pull. It is choking itself out and making peak power at around 5k RPM. No MIL/CEL, poked around looking at MAF readings and temp sensors and all seems correct. But LT Fuel Trim is -17 to -20 on both banks. The car has the dealer installed GMPP CAI, so I swapped that out to the stock setup when I got home to see if the LT FTs would be better, but no dice, still in the negative upper teens driving around and holding at 2k RPM sitting in the driveway (no load). Double checked all connections, cleaned MAF, no change. I really don't want to take it to a dealer. I know what kind of gamble that is to find a competent tech and advisor (I was a tech many moons ago). But I feel like maybe the calibration is bad in this car? It is acting like the MAF scaler tables are off, but come on... it literally has 3k miles. How? Does the GMPP dealer installed CAI come with a calibration flash? Appreciate any ideas. |
08-11-2019, 12:25 PM | #2 |
Drives: ZHP, Alfa 4C, RAM, X5, 17SS1LE-sold Join Date: May 2017
What mode was your car in? S, Track, etc do not allow for all available power. Double click TC button in either the above to access all power. See the PTM demystified sticky at the top of the forum section for complete information.
08-11-2019, 12:28 PM | #3 |
Sport, Competition Mode
08-11-2019, 12:40 PM | #4 |
At TPIS we had more time and played with settings a bit.
In Sport mode with TCS off it made 306 RWHP. In Sport mode, Competition mode, it made 335 RWHP. Both are 10.2-10.5:1 AFR and power flattens out at ~5100 RPM. We also yanked the air filter for a pull but it made no difference at all. Do these cars have problems with the TB blade not opening all the way but telling the PCM all is well? It shows 100% throttle when I floor it on the scantool. |
08-11-2019, 12:45 PM | #5 |
Drives: 2017 1ss 1le Join Date: Sep 2015
subscribing for updates! good luck
08-11-2019, 01:53 PM | #6 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
The PTM modes should have zero affect on the power level unless you are the wet or snow modes. Tour, Sport and Race will all have the same power, just changes how the power is put down to the ground on the ramp in rate for the TB opening. At 100% WOT on a scan tool the TB will report 83% open, that is normal from what I have seen on scans. Do you know if the dyno operator turned off the traction control before the run?
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
08-11-2019, 02:02 PM | #7 |
Drives: 2021 Tesla Model 3 LR Join Date: May 2016
The GMPP CAI should come with a tune I believe that the dealer should have done. Unless I am confusing it with something else.
08-11-2019, 02:14 PM | #8 |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
If everything else is normal and your long term fuel trims are what you say they are, most obvious culprit tends to be a MAF. Seen this a few times in my tech days.
08-11-2019, 02:25 PM | #9 | |
At TPIS, TCS was always off. Just ran once in regular Sport with TCS off, then again in Sport with TCS and Stabilitrak off and in Competition Mode. Made a few pulls in each mode and things were consistent to what I stated in the first post for power and AFR. When I mashed it to the floor in neutral in the driveway, it read 100% throttle on the Snapon scantool I have. I did read the "PTM demystified sticky" thread, and I have been using Comp Mode in Sport for pretty much everything except AutoX. |
08-11-2019, 02:27 PM | #10 |
08-11-2019, 02:31 PM | #11 | |
I wish I had a known good MAF I could toss in and try out. I bought this thing in part so I DON'T have to tinker with the damn thing all the time. I have an 87 GTA that gets far more of my time and energy than it should for that stuff...lol. |
08-11-2019, 03:16 PM | #12 |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
Sounds very similar to what member TIM M went through. Power way down and running rich. Check out post #75 in this thread for dyno results...
https://www.camaro6.com/forums/showt...=542089&page=6 Turned out to be an incorrect tune installed by dealer when the cold air intake was installed. See post #108 https://www.camaro6.com/forums/showt...=542089&page=8 Nigel |
08-11-2019, 07:02 PM | #13 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
Sounds like the same thing he went through.
'18 1SS 1LE Black, PDR
08-11-2019, 09:50 PM | #14 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
Yep, sounds like the exact same issue as stated above.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
