Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 09-15-2021, 05:13 PM   #1
C@mero
Drives: Camaro 1LE
AGP/Squash/Fore
Looking at these 3 options as a triple pump setup. The squash has the 2 525s as an upgrade, and from the looks of it it can support 700hp per pump. Planning on e85 and eventually go bigger down the road with my blower. Seems like the squash won’t be enough.
AGP and the Fore is pretty much the same unit (I think), but from the looks of it, with the AGP I would have to source out my own lines. There’s 3 options for FORE L2/3/4, which out of the unit is more of a plug and play/easier to install and better bang for the buck?
I’m assuming I would need the housing for AGP & Fore?
C@mero is offline   Reply With Quote
Old 09-15-2021, 05:35 PM   #2
AresSupersport
Drives: 2010 Camaro SS
I run the Fore triple 450 unit. I bought just the hat and pumps from Fore and sourced the feed line, Hobbs switch, relays, wiring, fuel rails, and regulator myself, and used the stock feed line as the return for now. It has worked great at 825hp on e85 so far with tons of room to grow, and I saved a ton of money vs a "plug and play" system.
Sent from my S61 using Tapatalk
AresSupersport is offline   Reply With Quote
Old 09-15-2021, 06:56 PM   #3
C@mero
Drives: Camaro 1LE
So would the stock line limit the power at all?
Crap wrong section..
