04-09-2021, 09:50 AM | #1 |
Drives: 2015 Camaro Rs 1LE, 1967 RS Camaro, Join Date: Jan 2021
Front Goodyears cupping
I have a 2015 2SS 1LE. It has the orriginal 285/35/20 on it. Just turned 10,000 Mile on them. Over the last year or so they have got progressively louder. This yearon the lift while cleaning i noticed some cupping on the front tires. What could be the cause? Are they just getting old reaching the end of their life? I would like to hear some other views. The car handels great and runs down the road straight. Let me know thanks Mike
04-09-2021, 10:12 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
How many miles on the car/suspension? Worn suspension (mainly shocks) could cause the wheels to bounce more than the should, resulting in cupping. Any suspension work done or all original? Know your alignment specs?
04-09-2021, 10:29 AM | #3 |
Goodyears cupping
10,000 mile on vehicle, all orriginal
04-09-2021, 03:48 PM | #4 |
Drives: 2010 2SS/RS, VR ext/Blk Int Join Date: Jul 2012
04-09-2021, 04:18 PM | #5 |
Goodyears cupping
Thanks for the info
04-09-2021, 09:19 PM | #6 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Got any pictures? Is the cupping over the entire width of the tire? Or is it more of a feathering on the outer shoulder? What are the alignment specs?
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
04-09-2021, 09:25 PM | #7 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Mine are cupping a bit on the front too but I know the exact reason. No front sway bar.
04-10-2021, 04:41 AM | #8 |
Drives: 2012 1LT Join Date: Nov 2015
Shocks most likely, however with only 10,000 miles I'd get an alignment first.
04-10-2021, 08:30 AM | #9 |
Sorry i dont have any pictures, The cupping is on the outside in the treads the aim towards the outside of the tire, I have never had it to the allignment shop.
04-10-2021, 08:43 AM | #10 |
04-10-2021, 12:58 PM | #11 |
I’ve had people tell me they have cupping and when I look at the tires I would not call it cupping. The outer tread blocks have a feathering pattern which is usually from inadequate negative camber or heavy cornering.
04-27-2021, 11:25 AM | #12 |
Drives: 2013 zl1 vert Join Date: Dec 2018
My Goodyear’s after 21k miles. I only noticed when i removed the rims for my new set.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
04-27-2021, 06:09 PM | #13 |
Holy crap!! Man that is right there with "man we're lucky we didn't have a problem" wear... Wow that could have been bad..
04-27-2021, 06:29 PM | #14 |
The funny thing is the other side of the tire has just normal wear, all even. I don’t even know how long it’s been that bad. Never a vibration.
