04-08-2018, 03:27 PM | #1 |
Drives: 2014 Camaro 2 LT Join Date: Nov 2013
SWC, REAR CAM and GPS dont work.
Hey guys,
I have the RPK5 from PAC Audion and Atoto A6. Everything is working well but the SWC, Rear Cam and GPS dont work. Any help would be very appreciated. ATOTO A6 https://www.amazon.com/gp/aw/s/ref=is_s?k=atoto+a6 RPK5 https://www.amazon.com/gp/aw/d/B01M0...-AL&ref=plSrch Front of Head Unit Top of Head Unit How I connected the wires to the Head Unit Head Unit Without all the connected wires How I married the RPK5 Radio Connections to the Atoto A6 Power Cord (Pin Interface). I don't know where to "marry" the other four from the Pin Interface. There are no wires left from the RPK5 Interface Module that came in with the RPK5 PAC Dial Set to 7 (Pioneer/Other) These were also left from the RPK5 Radio Connections. The brown wires were loop wires. It says to cut it on the instructions. Also the Nav Outputs wires left. Don't know where to marry these guys No GPS when I tested the Head Unit. Same with any other GPS Apps Any help would be greatly appreaciated. Thanks! |
04-09-2018, 11:50 AM | #2 |
Any info?
12-27-2018, 12:55 PM | #3 |
Drives: 2012 camaro 2LS Join Date: Nov 2016
Hey dude I go the same system. Did you buy any aftermarket wiring harnesses?
3.91 Gears, Ported Intake Manifold, Intake Manifold Spacer, 80mm Throttle Body, Cold Air Inductions Intake, Trifecta Tune, Solo HighFlow Cats, BBK 2.5"Xpipes, ZL1 Mufflers, Forgestar F14 wheels
250lb weight reduction !!! |
07-13-2019, 04:58 PM | #4 |
Drives: 2010 camaro Join Date: Jul 2019
I found a work around for adding swc to a camaro that different come equipped. You will save at least 250 bucks. I did it to my 2010 camaro. And didn't even have to get the bcm reprogrammed.
Sent from my SAMSUNG-SM-N920A using Tapatalk |
05-29-2020, 03:20 PM | #5 |
Any updates on your GPS? I'm looking at that head unit right now for my PAC install.
Thread Tools | |
