08-27-2016, 02:49 PM | #169 |
Drives: Twin turbo G8 GXP Join Date: Dec 2012
08-27-2016, 03:26 PM | #170 | ||
Drives: 2021 Camaro LT1 Join Date: Aug 2013
What else is on here to give it that sound? Sounds more than just an exhaust and the turbo kit. Is there a cam installed or anything else helping that sound? sounds mighty fine. Exactly what I'm looking for actually. |
08-27-2016, 05:30 PM | #171 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
Took a run at it at the track today.
Best 60 ft was 1.68 Best ET was 11.28 Best mph 123.69 mph DA was between 950-980 AGP kit with 56/61 BW turbo's .82 AR Circle D 3000RPM converter(ZL1 tranny) 3.23 gears(ZL1 diff) 325/45/17 M&H DR 223/239 cam.Stock heads & short block. 3" Kooks exhaust.Stock suspension. This was with only 5 PSI of Boost. 4200lbs w/driver
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
08-27-2016, 05:52 PM | #172 | |
Drives: 2013 ZL1 Join Date: Jan 2015
2013 A6 ZL1
08-27-2016, 06:18 PM | #173 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
08-27-2016, 06:19 PM | #174 |
OMWTFYB
Drives: ZL1 Join Date: Sep 2011
Thought all zl1s had 3.73?
08-27-2016, 08:29 PM | #175 |
3.73 rear gear ratio (M6) / 3.23 rear gear ratio (A6)
Cai intake and a few other mods😎
08-27-2016, 09:01 PM | #176 |
I had the 3.73 diff in it a few days ago.it was about 0.2 slower.Had a tiny bit of tire spin in first and second and the tranny was shifting in fifth gear.
Yeah I know,5 psi is not much.lol...I wanted to set the shift points on the tranny and I was curious on what it would do at only 5 psi. Next round will be more.Maybe a whopping 7 psi.lol....
08-27-2016, 11:27 PM | #177 |
Always Workin
Drives: 2021 Mazda MX-5 Join Date: Aug 2013
You need at least 10 psi!
2023 Vivid Orange 1SS 1LE 6MT
Arrived 8/31 Purchased 9/3 2018 1SS 1LE, HyperBlue Metallic (Sold) 2014 1SS 1LE, Black, Twin Turbo (Sold) |
08-28-2016, 06:59 PM | #178 | |
Too much is never enough!
08-30-2016, 10:47 AM | #179 |
Hey fellas,
Do not recall if I asked this previously, if so, I cannot seem to find it. Anyone know where in the PA, CT, NY, DE, and preferably the NJ area, they would be able to install the AGP twin turbo kit on a stock Camaro? With reasonable prices but excellent work of course |
08-30-2016, 11:41 AM | #180 |
Rpm in Delaware has done them. Great shop. Kevin has a lost of dealers and installers. Call him.
Nick
Corvette Z06 -1200ish rwhp |
08-30-2016, 11:49 AM | #181 | |
We will provide Premium customer service, workmanship, and tuning. Feel free to give me a call. Thank you Ted.
www.jannettyracing.com
10-02-2016, 10:16 PM | #182 |
J.Sick
Drives: 2010 Camaro SS Join Date: Nov 2010
Turbos: 54/57 journal bearing .82ar
Motor (CI): Stock LS3 Cam: stock Trans: stock TR6060 with Monster triple disk Fuel System: Squash dual pumps and ID-1700's Meth: No E85: Flex-fuel sensor Installed/ Tuned by: Installed by me tuned by Bill @ Arizona Elite Motorsports Horsepower/Torque Numbers at Boost level: 712rwhp & 653rwtq @ 10psi boost on E85 1/4 mile time/speed: Not run yet 1/2 mile speed: Not run yet Standing mile speed: Not run yet
"J.Sick"
2010 Camaro 2SS |
