Old 10-28-2016, 11:14 PM   #2563
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Submitted for bolt ons
etmx183 is offline   Reply With Quote
Old 10-28-2016, 11:16 PM   #2564
etmx183
etmx183's Avatar
Tires used on the pass:M&H drag radials
Performance Mods (if any):80mm throttle body E85 RX catch can, Nitrous Outlet Plate system, APEX air scoop, SOLO HFCs, JacFab ported manifold and upper intake isolator, Solo cat back Mach X system, 3.91 gears, Weld RT-S, 1 piece DSS driveshaft Stall convertor by:CIRCLE D
Transmission:A6
Category submitted for: Bolt-ons
R/T...........278
60'.............1.835
330'...........5.434
660'...........8.457
660’ mph...81.14
1000'..........11.012
1320'..........13.176
1320’ mph…105.86
Name of the track: Captiol Raceway
Date of pass:10/28/2016
DA: -491'
Old 10-28-2016, 11:40 PM   #2565
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Getting closer to #1
Tires used on the pass: 305/55/R18 Nitto NT05R
Performance Mods (if any): Vortech SCi with 2.91" pulley, 81mm Throttle Body, Ported LFX manifold, ARH LT Headers, ARK DT-S, Water Methanol Injection, 3.91 1LE Gears, JRE Posi Mod, 1LE Axles/Hubs, BMR Trailing Arms + Toe Rods + Subframe Bushings + UCA Bushings, Circle D 5C Torque Converter, Custom HP Tuner tune
Transmission: Auto
Category submitted for: Forced Induction (Stock Internals)
R/T.......... 0.203
60'............. 1.644
330'........... 4.683
660'........... 7.223
660’ mph... 97.19
1000'.......... 9.414
1320'.......... 11.268
1320’ mph… 120.11
Name of the track: Thunder Valley Raceway Park
Date of pass: 10/28/2016
Weather: Track Elevation - 1165, Air Temp - 71.6, Pressure - 30.09, Humidity - 64%. DA = 2278
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 10-29-2016, 06:40 AM   #2566
etmx183
etmx183's Avatar
Congrats,
BTW thanks for all your help.
Old 10-29-2016, 08:26 AM   #2567
MagnumForceGB
Originally Posted by etmx183 View Post
Congrats,
Thanks.
Might be able to raise the pressures to jerk the torque converter higher and also reduce the shift time by 0.1 seconds.
Old 10-29-2016, 10:47 AM   #2568
etmx183
etmx183's Avatar
I'm game to give it a try, will be another payday if I get into those 13.0x. :-)
Old 10-30-2016, 01:51 PM   #2569
racergirl
racergirl's Avatar
Drives: 2014 Red Hot 2SS/RS A6 Camaro
Will update tonight
Current Camaro: 2014 2SS
Performance Mods: BBK Headers, Borla S type axle back, tune, TSP Stage 1 cam, Vararam Intake, DR's
11.77 @ 119.21
Former Camaro: 2013 2LS
BONE STOCK: 13.953@100.77 With Bolt-Ons: 13.646@101.60
With 75 shot and Bolt-Ons: 12.587@111.25
Performance Mods: CAI Intake, MRT V2, SLP Underdrive Pulley, DRs, Skinnies, Rear seat delete
racergirl is offline   Reply With Quote
Old 10-30-2016, 08:58 PM   #2570
racergirl
racergirl's Avatar
Great passes guys! Lists have been updated!
11.77 @ 119.21
Old 10-30-2016, 09:00 PM   #2571
etmx183
etmx183's Avatar
Thanks for keeping the list going. The bolt ons list is still my old run.
Old 10-30-2016, 09:41 PM   #2572
racergirl
racergirl's Avatar
My bad. All fixed
11.77 @ 119.21
Old 10-31-2016, 07:53 AM   #2573
etmx183
etmx183's Avatar
Thank You. I know it is a lot to keep up with.
Old 12-04-2016, 05:12 PM   #2574
etmx183
etmx183's Avatar
Bolt-on V6 Fast list
Old 12-04-2016, 05:16 PM   #2575
etmx183
etmx183's Avatar
Performance Mods (if any):80mm throttle body E85 RX catch can, APEX air scoop, SOLO HFCs, JacFab ported manifold and upper intake isolator, Solo cat back Mach X system, 3.91 gears, Weld RT-S, 1 piece DSS driveshaft Stall convertor by:CIRCLE D
Transmission:A6
R/T............246
60'.............1.865
330'...........5.421
660'...........8.388
660’ mph...82.66
1000'..........10.902
1320'..........13.037
1320’ mph…105.23
Date of pass:12/4/2016
DA: -1100
Old 12-04-2016, 05:17 PM   #2576
etmx183
etmx183's Avatar
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
Modern Camaro Performance - Lowest Prices Anywhere! PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 11-03-2010 10:50 AM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 04:26 PM
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List GQ4Life Dragstrip and Launch Techniques Discussion 17 07-07-2010 12:31 PM
