Old 01-13-2010, 12:11 PM   #1
Sherwood SS
Sherwood SS's Avatar
Drives: Black SS/RS
Aftermarket Exhaust rattle
After installing the magnaflow 2.5 comp series cat-back exhaust, I have had a rattle that's coming from the plate that goes back after install. The plate sits in the middle of where the resonator was on my L99. It only hits the plate when I hit a bump in the road. I put a few spacers under the plate which did the trick for awhile, but it's starting to come back. I am going to loosen the whole set up and put a wood block bt the plate and exhaust, retighten, and then remove block this weekend( advice from magnaflow). Hopefully thus will fix it
I was wondering if anyone had a similar experience, advice, or input for me. Also thoughts on removing the plate (is it necessary to have?) thanks in advance!
Black SS/RS - Magnaflow Comp Series, Eibach Suspension, Roto-Fab Intake
Sherwood SS is offline   Reply With Quote
Old 01-13-2010, 12:20 PM   #2
eynigush
SoCal C5 Family Member
eynigush's Avatar
Drives: 2010 Camaro SSRS Rally Yellow
Happened to me at first. I loosened everything up, repositioned, and tightened everything down. No issues since.
-Eddie
Kooks 1 7/8 headers w/high flow cats
Magnaflow Cat-back Competition Series
Cold Air Intake by CAI Inc.
eynigush is offline   Reply With Quote
Old 01-13-2010, 01:00 PM   #3
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
My SLP set up instructs to leave the plate off, Just use the bolts to secure the heat shield.
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Custom Magnaflow Exhaust buddylok Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 49 05-16-2016 11:02 AM
New low profile electric exhaust cutouts for your Camaro @ PFYC.com Redshift V8 Bolt-Ons & Tunes 8 08-14-2014 04:19 PM
RATING HEADERS??? SAUCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 12-02-2011 08:21 PM
Aftermarket exhaust? RSSSIOM 5th Gen Camaro SS LS LT General Discussions 13 01-04-2010 10:43 PM
Which Aftermarket Exhaust is the best for the V6? 101ABN Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 29 12-05-2009 04:18 PM
