09-20-2011, 09:25 AM | #1 |
Drives: 2010 Camaro 2SS/RS - L99 - CGM Join Date: Apr 2010
800RWHP + owners... Do you drive your car everyday?
To all you blown or boosted owners out there making 800RWHP +. Do you drive your car everyday?
Driver that do drive everyday with their car: How is the drive? A6 or M6? I'm speculating that with a 416ci, running 61mm turbos, I'll be around the 800 - 900 RWHP. I'm also assuming that I'll have two settings, one low boost ~12lbs and the second at ~17lbs. Do you guys have the same projected setup? Or do you run all power, all the time?
2007 Corvette Z06 - Velocity Yellow
Halltech | Forgestar | Bilstein |
09-20-2011, 10:29 AM | #2 |
Drives: Anything I want Join Date: Oct 2008
My customersdrive theirs.
09-20-2011, 10:48 AM | #3 |
Boosted Moderator
I drive mine all the time.... Keep it out of boost and it's like driving a strong stocker....a really strong stocker
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
09-20-2011, 10:50 AM | #4 | |
How much boost are you running? Do you have two settings?
09-20-2011, 10:55 AM | #5 |
Boosted Moderator
12 lbs right now, but we are soon to see how far the 93 lb/hr injectors will take us, adding boost until we see a drop in fuel pressure or start maxing the duty cycle beyond our limits....
Once that's determined, it's time for some racing fuel to mix with a 150 shot of nitrous... We figure this will get us in the 1200 rwhp range...
09-20-2011, 11:21 AM | #6 | |
Drives: 2010 Join Date: Jul 2009
Ya HOO!!!!! |
09-20-2011, 11:30 AM | #7 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
I use mine as a daily driver when I want to cruise around or go to car events or go to the track. Yes I can drive mine around max boost with no issues or lack of drivability.
09-20-2011, 01:54 PM | #8 |
Bigdog drives his all over the state to all of the car shows he can attend.
www.jannettyracing.com
09-20-2011, 02:00 PM | #9 |
What's your average MPG?
09-20-2011, 02:46 PM | #10 | |
Drives: 2SS Victory Red Join Date: Jul 2009
09-20-2011, 02:48 PM | #11 |
Drives: ZL1 Camaro Join Date: Feb 2009
I'm not pushing that much HP, but I can....I currently run 10 psi of boost for dd duties, I drive to work everyday and on weekends...I put around 12k miles a year on the car....I am planning on adding additional boost at the track soon....need to finish up some things and tune it.....
09-20-2011, 03:07 PM | #12 |
Sunday morning I drove my Vette from LA to Phx AZ 423miles and then Monday night I drove back. Round trip it averaged 71.2 mph at 21.3 mpg.
Spec: Manley Pistons: 596170C-8 Manley Rings: 46117ST-8 Manley/Granatelli 1000HP rods: 14051R-8 Granatelli Stage 3 CNC ported Cylinder heads: Granatelli Signature Series performance cam shaft – 850-16 LS3 full Travel Lifter ARP Main Studs: # 234-5608 ARP Head Studs: # 234-4317 Main Bearings:Hi Po replacements Rod Bearings:Hi Po replacements Cam Bearings:Hi Po replacements Head Gaskets: Stock Replacment Granatelli Twin Turbo kit at 12psi 808 rwhp & 814 ft/lbs So figure that is an easy 900plus at the crank. The car is as docile as stock until to lean on it. That is the beauty of turbos over most other power adders. Dr Jeckle and Mr. Hyde personality on and off boost. |
09-20-2011, 11:27 PM | #13 |
I drive mine anytime there is nice weather! I drove it normal once...
Forged 418 w/Whipple 2.9L RMCR Tune
786 RWHP 745 RWTQ[/SIZE][/COLOR] Manley Crank, Wiseco Pistons, Compstar H Beam Rods, ARP Main/Studs, Copper Treated "hi boost" head gaskets, FI Cam & Ported Heads w/Manley Extreme Duty Valves, Lunati Link Bar Lifters, Fuel System w/LPE Dual pumps, Twin Fuel Feed line/Single return w/ boost reference regulator, NW 102mm TB, 10-Rib ASP custom pulley kit, Twin RX Catch Cans, Roto Fab CAI, TSP Stainless Headers, Spec Twin Disc P-Trim Clutch, DSS Level 5 Axles, Eibach and BMR Full suspension |
09-20-2011, 11:56 PM | #14 |
Boosted Moderator
describe this please, I'm not sure I understand this word....... Normal....???
Similar Threads | ||||
Sooooo...I guess I'm sending the car to Livernois! | rdblan2 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 86 | 10-17-2011 12:48 PM |
White Camaro ZL1 with Automatic Transmission... First Pics... | JoeP@TeamBeckyD | Camaro ZL1 Forum - ZL1 Specific Topics | 182 | 08-12-2011 09:13 AM |
Winner, winner - Jalopnik compares the Big 3 | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 31 | 04-17-2011 03:24 PM |
My Story on Geting my Dream Car. | aberafik | USA - California | 7 | 10-07-2010 02:24 AM |
Robin Roberts To Drive Indy Pace Car | Info@PeddersUSA.com | Camaro Photos | Spyshots | Video | Media Gallery | 7 | 04-01-2010 11:15 PM |
