07-18-2018, 01:30 PM | #1 |
Drives: 1999 Camaro SS Join Date: Apr 2016
Overdrive pulley...
So what OVERdrive balancer set up is everyone running that is no LSA?
How much overdrive are you running, ex. 8%, 10%, 12% etc Does ATI make a complete 8 or 10 rib pulley kit? Thanks |
07-18-2018, 01:54 PM | #2 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
10 rib ati 6% od here
Sent from my SM-N950U using Tapatalk |
07-18-2018, 03:48 PM | #3 |
NICE!!! why only 6%? because 10 rib?
^^ Can I get that part # by chance? |
07-18-2018, 05:58 PM | #4 |
The bottom one 10 rib, 6%od is the max
07-22-2018, 06:48 PM | #5 |
I believe Innovators West offers a 10% OD, as well as a complete pulley kit.
07-23-2018, 02:17 PM | #6 |
Drives: 2010 VR 2SS/RS M6 Camaro Join Date: Feb 2010
You should look at diameters instead of % with these. Innovators West say 10% but it's actually an 8" crank. The ATI 6% OD balancer is actually 8.19" so bigger than the Innovators. ATI 4% OD is 7.95" and that's what I have.
I never understood Innovator's % because they say std diameter is 7.25" when it's really 7.5" on our cars. |
07-23-2018, 02:26 PM | #7 |
My ati od 10 rib balancer us 6% od. 8.19
07-24-2018, 01:32 PM | #8 | |
07-25-2018, 09:44 AM | #9 |
All of the percentage calculations were made based on the LS1 Corvette back in the 90s, GM has since changed the balancer standard size many times so what is listed as a 10% over the old LS1 might only be a 4 or 6% on the LS3.
I got bit by this back in 2010 when we purchased an IW Standard size 8 rib and ended up with less boost on a Maggie, turns out the standard size is not standard for an LS3.
www.jannettyracing.com
07-25-2018, 10:55 AM | #10 |
So does anyone know the standard size of a stock 2012 Camaro LS3 balancer?
Been looking online and from what I found is 7.7" Can anyone confirm? |
