03-24-2021, 11:56 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2019
E85 Kit Alternatives
I have a 2010 SS and have purchased a E85 Harness for 74 Dollars and an actual GM Flex Fuel Sensor for 56 Dollars. What is a GM Part Number for a Fuel Line like they use in the kits?
03-25-2021, 08:25 AM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
The kits I have seen did not use GM parts for the lines. They used EFI to AN adapters and AN lines. Summit has all that stuff.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-25-2021, 08:28 AM | #3 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
The DXS kit is complete, well engineered, and comes with lucid complete install instructions. Worth the extra bucks to not have to piece it together yourself...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
03-25-2021, 10:01 AM | #4 |
Drives: 2012 Camaro SS Join Date: Dec 2019
https://www.lethalgarage.com/collect...2015-camaro-ss
Lethal garage sells it with a OEM fuel line I just don’t know the part number
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-25-2021, 02:26 PM | #5 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Look at Motion Race Works they have a cool set up?
https://www.motionraceworks.com/coll...n-6an-8an-10an
Orange Krush II
03-28-2021, 11:19 PM | #6 |
I totally appreciate all the replies. I am simply looking for a Part Number of a GM Fuel Hose that will work for this. If I find it cheap enough, I will save over 100 Dollars if I had bought a kit. I already have a new harness and Flex Fuel Sensor
