02-04-2011, 07:06 PM | #1 |
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS ) Join Date: Nov 2009
Roll cages?
Would someone please explain the differences in roll cages? There are 5, 6 and 8 point cages, right? HOW are they different, and what purposes do they serve? Which are welded into the car? Which requirements must they satisfy?
02-04-2011, 07:18 PM | #2 |
Quit being a pu$$y
Points are how many spots the roll bar/cage is tied to the chassis. Obviously the more points you have the more complex and costly it will be. Also the faster you want to go the more points you will need.
The least you can have and be legal to race is a 5 point (depends on where you race and how fast you want to go), which is the regular hoop, the two rear tie ins and the driver door bar. This is what i had in my 98 SS daily driver. It's the least restrictive because there is no door bar for the passenger side.
02-04-2011, 07:21 PM | #3 | |
el Ruco
Fast and gettin' faster.
02-04-2011, 07:25 PM | #4 |
Prefer to be blown!
Drives: 2010 Silver/Black 2SS/RS Manual Join Date: Mar 2010
Faster than 11.5 you get into the cage roll bar requirements. The cages run around two grand and up. You should order a 2011 NHRA rule book.
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
02-04-2011, 07:26 PM | #5 |
Prefer to be blown!
Just saw your signature, how improved is it?
02-04-2011, 07:29 PM | #6 |
Quit being a pu$$y
You don't buy a roll bar/cage for how fast you are going, you buy one for how fast you ultimately want to go. Like Silver2SSRS6spd said, get a rule book and it will tell you EXACTLY what you need top run how fast. Once you know what you need you can start asking for recommendations.
02-04-2011, 07:42 PM | #7 |
Prefer to be blown!
There are driveshaft safety loops, scatter shields and lots of other things that you will need as you get faster. Racing ain't cheap!
02-04-2011, 08:37 PM | #8 |
el Ruco
It pulls...
Well, lessee. There's a KB twin screw blower, ported heads, a blower cam, Borla LT headers with no cats, Borla exhaust, an Adam Montague at ST Motorsports custom tune, 18"drag radials on Corvette rims (soon to be replaced with 17" drag slicks on Bogart wheels with Bogart skinnies up front), BMR drag suspension all around, third stage dual disc ceramic clutch, rebuilt and reinforced 6060 tranny (I broke the original output shaft by pushin' it a bit too hard), driveshaft loop, shift light, et cetera. I'm planning on puttin' a 5 gallon ice box in the trunk to help cool the blower. The bottom end is still stock. I'm runnin' 8 or 10lbs boost depending on the pulley. It's gettin' 625 hp at the rear wheel on California's shit, 91 octane pump gas. It runs a good deal harder on 110 octane juice...
Does that answer your question? |
02-04-2011, 08:39 PM | #9 | |
el Ruco
02-04-2011, 09:37 PM | #10 | |
Drives: 2010 Camaro Join Date: Feb 2010
A 5 or 6 point roll bar will do you fine. And don't forget that you will also need a 5 point harness and a scatter shield for that trans. |
02-05-2011, 12:17 PM | #11 |
el Ruco
02-05-2011, 12:41 PM | #12 |
Drives: 2010 ZL550& 2021 C8 Z51 Join Date: Feb 2010
There is a group buy for bolt in roll bars right now. Here is the link.
http://www.camaro5.com/forums/showthread.php?t=127127 |
02-05-2011, 09:16 PM | #13 |
Drives: 2010 SS Camaro Join Date: Aug 2010
2010-2011 Camaro NHRA LEGAL 11.50 to 10.0 Roll Cage
Ivas,
It sounds like your combo is really starting to develop and with 10s in the future, a cage is mandatory or you will get booted from the track. In fact, runnning at 11.2 right now without one is illegal and in all reality, not safe if something were to happen. Some critical and important points to make on roll cages for the 11.50 to 10.0 as per NHRA rules:
With those rules out there, its clear that a lot of the so called NHRA legal bars are not up to spec. What you dont want to have happen is to install an expensive peice of jewelry that'll get you booted off the track. Do it once, do it right, and have the confidence that your purchase was a sound decision for both your wallet and your safety. We offer the perfect solution for someone who is looking for a bolt in, fully NHRA legal 11.50 to 10.00 roll cage at nearly half the cost of a custom cage. Best part, you can install it yourself on a saturday and still have time to make it to the track that same night. Features
As lewylew said, we are having a group buy going on right now! Its a great opportunity to get into a legit cage at a super low price! |
02-09-2011, 09:05 AM | #14 |
IVAS,
Heres a link to the new, official group buy page. We are just about to hit our mark on huuuuugeeee discounts on this awsome certified Roll Cage. Hope all of you questions were answered above. Let us know if you have more! http://www.camaro5.com/forums/showthread.php?p=2808191#post2808191 John@trackspecmotorsports.com |
Similar Threads | ||||
Bolt In Roll Bars- 100% NHRA LEGAL| FULLY WELDED|FULLY COATED|FREE SHIPPING! | Trackspec Motorsports | Suspension / Chassis / Brakes | 43 | 05-28-2011 12:07 AM |
Farks Supercars Camaro roll bar PICS | Farks Supercars | Suspension / Chassis / Brakes | 13 | 10-20-2010 10:10 PM |
Who manufactures the strongest and thickest front sway bar? | 55Designs | Suspension / Brakes / Chassis | 36 | 10-01-2010 10:56 AM |
Pfadt or Eibach | DTS2SS | Suspension / Brakes / Chassis | 9 | 01-22-2010 12:07 PM |
Sway Bars. Myths, Knowledge, Understanding | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 24 | 11-16-2009 07:48 PM |
