06-17-2017, 03:14 PM | #1 |
Drives: 2015 Z/22 Join Date: Aug 2015
Good Alignment Shop in Hamilton
Just an FYI for anyone in the Hamilton area: I recently went to a shop called NV Auto on Centennial Parkway North (AKA highway 20) and had an alignment done, and the alignment was almost dead on side to side in only an hour's work (front camber and toe and rear camber were identical; rear toe had 0.01° difference; caster was different by 0.2° but I told them not to worry about the caster). I'm sure with another hour or less the alignment would be pretty well perfect. They also have no problem aligning lowered cars as other shops might, depending on their equipment.
