07-21-2020, 08:18 PM | #1 |
Drives: 2015 Chevrolet Camaro SS Join Date: Feb 2018
2015 Camaro SS L99 - Cam upgrade - Tuning Problems
After the engine upgrades listed below I took the car to a local tuner and he was unable to adequately tune leaving me with the following disappointments.
- ~800 RPM rough idle - Pulling at stop - Bucking at 1000-1100 RPM's in drive and sport mode - MPH hangs at 17-42 often - Hesitation out of the hole at full pedal - Heavy drone in a large range of speeds since the upgrade and tune - Heavy fuel smell exiting the exhaust 2015 Chevrolet Camaro SS - automatic 6.2L L99 - 68,000 miles Recent July 2020 upgrades include: - TSP Texas Speed; headers, high flow cats, 3" pipes, and mufflers. - BTR Brian Tooley Racing - L99 Stage II VVT Camshaft; ADV DUR: INT 275., EXH 291 Dur @ .050: INT 225, EXH 238 LOBE SEP: 113.0 VALVE LIFT: INT .612, EXH .586 - BTR Dual Platnum LS Spring Kit .660" Lift - BTR Chromoly One Piece Pushrods; 7.400" Long, 5/16" Diameter, .080" Wall - BTR GM LS Rocker Arm Runion Upgrade - COMP CAMS Cam Phaser Limiter - GM L99 - LS7 Hydralic Roller Lifters & Trays - ACDelco 6.2 Valley Cover - Melling M295 Oil Pump - NGK BR6 Spark Plugs - Denso Front O2 Sensors - Plus all gaskets, o-rings, bolts replaced (and torque specs performed) I want to make sure that the engine is set up properly as you would expect prior to tuning again with a new tuner therefore could you answer some other questions for me? Is there anything listed in the upgrade provided that you have questions or comments? What vacuum line (with catch can) routing do you recommend? Drivers side valve cover outlet Passenger valve cover outlet Valley cover outlet Intake manifold behind the throttle body Cold air intake tube Are NGK Tr6 Spark Plugs what you would recommend? Is the Melling M295 Oil Pump what you would recommend? Do you need specialized experience tuning L99 engines (with DOD Delete and VVT)? How long would the predicted tuning time be for this car/engine? What RPM should this idle be? Thanks for you help. |
07-21-2020, 08:32 PM | #2 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
what converter?
Sent from my SM-G975U using Tapatalk
Bone Stock |
07-21-2020, 08:35 PM | #3 |
that cam will need a looser than stock converter to act right. the stock converter is way too tight. car should be able to idld at 800. my cam us a 232/244 and idles at just over 800ish
Bone Stock |
07-21-2020, 08:38 PM | #4 |
07-22-2020, 09:03 AM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
You need a better tuner and looser converter, if it is still stock.
08-06-2020, 06:26 PM | #6 |
Drives: 2015 Camaro SS convertible L99 Join Date: Nov 2016
1st, check for any vacuum leaks (bucking and poor accelaration). 2nd, you may need a torque converter. 3rd, if it was Geof that did the tune after the install, he does not like tuning the VVT system and will not get the tuning tables for your cam. If it was Geof that did the tune he tume the timing at 8 and not more leaving the car with about 400whp.
I had the install and tune done by Geof almost 3 years ago. The install was on point but everything else was ok. My tune was crappy the timing was set at 8 and the car had 421whp, also the car had the intake tube lose a little on the throttle. My timing is now set at 25 and no more with my VVT3.2 cammed Gen5 vert and can be daily deiven with little to no bucking with my 3200stall converter. The smell of fuel comes with territory if you have no meows and there isn't enough change to change the fuel tables unless you are running boost. But anyways, after checking everything dump the previous tuner and bite the bullet. If I was you I would buy the HP tuner software and 3 credits and have the car tune remotely since there aren't that many tuners that can tune cars with VVT 6.2 camaros in our area. Most tuners here will tell you to delete the VVT/DOD system entirely, because they can not really tune it, will lie and say that the car will make more horsepower with the VVT delete with no foundation. Some will try to tune it and use your car as a lab rat. I am sure that there maybe someone far away from Orlando that can help you tune it right. And go and put a converter with a cooler. |
