Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Suspension / Chassis / Brakes
Old 09-22-2015, 09:06 AM   #1
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
peddres zl1 rear sway bar and zl1 rear arms
Pedders zl1 rear sway bar $200
rear zl1 rear arms $100
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 09-22-2015, 04:49 PM   #2
woodside783
Casey Woodside
http://www.camaro5.com/forums/attach...1&d=1442958582
Old 09-22-2015, 05:29 PM   #3
Silverbackcamaro
Silverbackcamaro's Avatar
Drives: 2010 Camaro RS/SS
Would probably be to much to hope that these would fit an ss wouldn't it
2010 Camaro SS. Nightfury cam, JBA headers, Vararam CAI, Hurst Short Throw, Ported TB, Custom Borla XR-1 Exhaust. TCW Wheels. Tuned by Lethal Racing. 484 rhp, 465 ft-tq.
Silverbackcamaro is offline   Reply With Quote
Old 09-23-2015, 06:36 AM   #4
woodside783
Casey Woodside
It will on 2012 and up camaros
You will need the zl1 arms on 2010- 2011
Old 09-23-2015, 09:38 PM   #5
Casper954
Casper954's Avatar
Drives: 2010 Camaro 2SS
Are you talking about zl1 lower control arms? If so pm me please and I'll take them for 100 shipped
Appearance: Blacked out tail lights, Oracle Plasma fogs, SLP Carbon Fiber splitter, Carbon Fiber Hash Marks, Carbon Fiber ZL1 hood, 20" Giovanna Kilis rims, Eibach lowering springs
Performance: Straight-piped magnaflow exhaust, K&N intake
Casper954 is offline   Reply With Quote
Old 10-03-2015, 11:07 AM   #6
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Free Bump-
I believe as long as you have 2012up rear lower control arms (with the outboard mounting points), this sway bar will fit any Camaro including all V6's with their standard brakes! No upgrade to Brembo's necessary.
This is a 32mm FE4 bar that is very versatile...
Old 10-03-2015, 03:02 PM   #7
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
Originally Posted by Ventmaster View Post
Free Bump-
Correct. FE4 Lower Control Arms and it will fit. I have it on my 2011. LCA's are cheap at the dealer. 55 bucks each I believe.
mp51998 is offline   Reply With Quote
Old 10-07-2015, 05:57 PM   #8
leviathandreams
Drives: 2012 Camaro 1LT Auto
If I have the fe2 suspension would the zl1 control arms fit and make the sway bar work? I thought I had to get brembos first.
leviathandreams is offline   Reply With Quote
Old 10-07-2015, 08:55 PM   #9
Ventmaster
Ventmaster's Avatar
Nope- you are good to go!
Buy the bar- it will fit your stock lower control arms! A 2012 can handle either style bar and the Pedders bar is compatible with V6 brakes.
I gave up waiting for one and got the JPSS bar- you can save $100 if you grab this one! You're welcome Woody!
Old 10-14-2015, 05:42 PM   #10
p.s.
Drives: 2014 v6 manual
You sure? My '14 v6 has fe2 suspension with the links on the inside of control arm. There are holes on the outside but I'm not sure if those are the ones that would be utilized. At the very least i think i'd need correct length sway bar links.
p.s. is offline   Reply With Quote
Old 10-14-2015, 08:14 PM   #11
Thekhriz
Drives: 2010 SS 2ss
Still Available? 10' SS. If I understand correctly the sway bar will fit, with the ZL1 rear arms?
Thekhriz is offline   Reply With Quote
Old 10-14-2015, 09:05 PM   #12
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
yes, get the LCAs and end links for a 2012+ and youre good to go with this bar
BronxxBombers213 is offline   Reply With Quote
Old 10-15-2015, 08:48 AM   #13
woodside783
Casey Woodside
thanks for all the help on here i have been busy and forgot to check this. had a lot going on
i am going to get some dse end links so i might as well sale the end links as well
Old 10-24-2015, 04:17 PM   #14
Ventmaster
Ventmaster's Avatar
Yes I am sure and yes you'd need the factory endlinks to go in those outboard holes. Grab this bar V6 guys- you will not regret it!
