Old 09-22-2018, 10:09 AM   #1
MrTwenty6
MrTwenty6's Avatar
Drives: 2014 Camaro SS 1LE
Cracked spoiler
I cracked my rear spoiler (1LE) - an overhanging tree branch while backing into a parking spot.
I'm sure there is no way to fix this but i'll post pictures in a few.
Any thoughts? Chuck it and get a new one?
MrTwenty6 is offline   Reply With Quote
Old 09-22-2018, 03:53 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
I'm sure it's fixable with fiberglass or something but unless you fix it/paint it yourself it may be cheaper to just get a new one.
KillboyPowerhead is offline   Reply With Quote
Old 09-23-2018, 06:23 PM   #3
JoelNR
King of the Lurkers
JoelNR's Avatar
Drives: 2010 SS/RS (Victory Red)
I'd say chuck it. The way the 3rd brake light is poking out on the left means it's probably tweaked just a bit and not just cracked.
Money aside, if you fix the top it could probably come out looking pretty good but it's probably delaminated in a larger area than what's visible.
'10 SS/RS M6
The go:
ESS supercharger kit, Speed Engineering headers, NGK TR6IX plugs, ZR1 MAP sensor, DSS driveshaft, BMR trailing arms & toe rods.
610 HP/556 TQ. Tuned by Ryan at KC Maxx Performance.
The less important bits:
MRR 228s, SLP front lip, ZL1 grille (no bowtie), Z28 spoiler with ZL1 Addons wickerbill, RPID tow hook, Sparks Restoration SS trunk emblem, ZL1 rear & Phastek front rock guards.
JoelNR is offline   Reply With Quote
