05-03-2018, 02:02 PM | #1 |
Back4Revenge
Aluminum /Carbon Driveshafts?
Gforce $8-900 and DSS $950-$1400 (carbon) each have their own.. Has anyone installed any of these? Community Reviews really help me jump the fence. ('10 S/c'd LLT)
I chose my 6 with Pride..
05-03-2018, 02:49 PM | #2 |
You pushing that much HP that you need to upgrade the drive shaft? To each his own I guess . Post pictures when you do it . At least it will look pretty.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
05-03-2018, 02:50 PM | #3 |
I have the dss 3.5” 1pc aluminum driveshaft
Instagram @orange_maro_
05-03-2018, 03:32 PM | #4 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
I have the driveshaft shop carbon fiber one piece driveshaft. Have no complaints. I would also get a driveshaft shaft loop to install at the same time. I went with the Metco driveshaft safety loop.
Edit: I didn’t notice it was for a V6. Not sure about that one, but driveshaft shop and G force are the both good brands
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
05-03-2018, 04:09 PM | #5 |
Back4Revenge
Dj how did the difference feel? Snappy launch/ more torque/ mpg increase? or Nada?
Everyone says something different, but I'd rather take it from those that actually have it on their Camaro's like you guys- Good to know these 2 are the routes go.
05-03-2018, 05:23 PM | #6 |
It is really hard to compare between the OEM 2pc and the DSS 1pc since i have been changing so much each time the car goes in. When the dss driveshaft was installed I also built the short block, installed the AEM meth setup, and retuned the car. So it is impossible to tell at this point. I would have to put my OEM piece back on to be able to give you any feedback. So far no complaints though!
05-03-2018, 07:40 PM | #7 |
So what do you have done to your car? I Really would like to know.
05-03-2018, 11:56 PM | #8 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
If you do replace your driveshaft an aluminum driveshaft is well worth it for some weight reduction. I wouldn’t get a carbon driveshaft as I have seen them not last too long and break at the track.
Mr. Clean
05-04-2018, 01:31 PM | #9 | |
Back4Revenge
Graphics add about 40 to the wheel eBay electric turbo Spectre cold air intake And full synthetic oil Lol jk, Mrt 2.0 Exhaust Long Tube Headers OverKill Supercharger With stage 2 ZL1 field pump Overkill Tuned With a Small Nitrous shot to be added. And hoping a gForce driveshaft
05-05-2018, 05:43 PM | #10 | |
05-05-2018, 07:53 PM | #11 |
'It's an experiment'
I have the DSS carbon:
2 years plus on it... -Don
747 RWHP 794 RWTQ
05-07-2018, 09:45 PM | #12 |
Back4Revenge
1coopgt YUPYUP
Hammdo: Did you install it separately or collective with other mods, Im trying to see if it's worth the switch,
05-07-2018, 10:06 PM | #13 | |
I was going for a road racing setup. So far, working for what I planned... Unless you intend to do some racing or serious power, the stock setup is pretty stout. Hard launches, maybe axles. I’d do bushings and toe rods first. I did all those items before doing the shaft/axles/hubs... -Don
747 RWHP 794 RWTQ
05-10-2018, 01:41 AM | #14 |
I did the DSS carbon fiber 1000hp in my 10' SS and immediately noticed a pedal difference between the two piece drive shaft... no delay. I pulled it out and have confirmed it will work in my new Z/28. One of my first mods.
2015 Camaro Z/28 Black
Sold: 2010 Camaro 1SS/RS |
Thread Tools | |
