Old 10-06-2016, 07:39 AM   #1
Highjumper
Highjumper's Avatar
Drives: 2010 2SS RS
Have to pull head. What to do to make it faster??
Well, looks like the head needs pulled off to check a low compression cylinder. Could be a burnt valve or lifter problem. Not sure. It's a 2010 LS3 Edlebrock SC. Nothing done to engine just bolt on's. SC, CAI, full SLP, fuel upgrades, oil pressure upgrades, booster, Catch Can etc.
Heads are coming off. QUESTION: What would you all recommend for any upgrades to make it stronger, faster, run better etc?? Top end.
Engine just hit 20k miles. SC has been on from 12k.
2010 SS RS "Cars are meant to be driven, enjoy the ride!!"
Highjumper is offline   Reply With Quote
Old 10-06-2016, 07:48 AM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
New lifters, dual valve springs, port and polish the heads. Of the three only one will gain you more power, but you would be foolish not to do the other two while your in there. My 2 cents.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 10-06-2016, 07:58 AM   #3
Scotty D2014
Drives: 2014 SS1-1le Crystal red metallic
What's the going rate $$ to pull heads and replace the lifters ??
Scotty D2014 is offline   Reply With Quote
Old 10-06-2016, 08:09 AM   #4
2k10camaro
Drives: 2010 Camaro 2SS RS
I'm with that guy on all but the lifters talk to Texas Speed about sending in for a CNC port polish and valve job buy new valve springs from them and titanium valves just my 2 cent
2k10camaro is offline   Reply With Quote
Old 10-06-2016, 08:36 AM   #5
Unreal
Drives: 2006 Z06
Find out what is wrong first. Odds are you lost a ring land, which means bottom end comes out.
I would just have the heads cleaned up, then put back in with ls9 gaskets/arp bolts and call it a day. No reason to put a ton of money into the heads on an eforce car.
Nick
Corvette Z06 -1200ish rwhp
Old 10-06-2016, 09:07 AM   #6
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
I'm gettin me one of these bad boys----https://www.amazon.com/Inspection-Camera-Cable-14-5mm-Waterproof/dp/B00CE3Y00C
+1 on stock rebuild if F/I....unless you are planning on turning up the psi? Then you might as well pull the motor and put in forged pistons and better rods...THAT will pay more dividends than any head mods...IMHO....fix it to last....saves $$$$ unless you got extra then I'll take some lol...peace out...
Old 10-06-2016, 09:27 AM   #7
Livernois Motorsports
Livernois Motorsports's Avatar
Drives: 2010 Camaro 454 LSX (SOLD)
Scotty D2014, We can have one of our vehicle installers write up a quote! If you give us a call at (313)-561-5500 ext:123 we can get more information on what other work you are looking to do and the install costs.
Here are a couple links to some of our heads and valvetrain options that we supply!
http://www.livernoismotorsports.com/cylinder-heads
http://www.livernoismotorsports.com/valvetrain
Livernois Motorsports is offline   Reply With Quote
Old 10-06-2016, 01:09 PM   #8
Highjumper
Highjumper's Avatar
Drives: 2010 2SS RS
Thanks
MKC Performance in Kansas City is going to pull the head and find out what is going on. I'll let you guys know when I find out. It was throwing misfires everywhere on all cylinders above 4k rpms. Ran good up to that. Running around 10psi with the eforce. 543rwhp and 569 torque.
Old 10-06-2016, 05:57 PM   #9
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
i didnt see a cam listed in your mods. id go cam and springs first. if you want more then port the heads.
supergt99 is offline   Reply With Quote
Old 10-07-2016, 09:02 AM   #10
SLY5ACE
Drives: 2013 camaro ss 1le supercharged
THERE IS A GOOD CAM AND VALVE SPRING PACKAGE FROM JDP MOTORSPORTS IM THINKING ABOUT PURCHASING THAT MYSELF FOR MY 2013 CAMARO 1LE
SLY5ACE is offline   Reply With Quote
Old 10-07-2016, 01:19 PM   #11
Highjumper
Highjumper's Avatar
Drives: 2010 2SS RS
Unreal is the Winner! Lost ring land. Pistons not in great shape either.
Going to go ahead and let MKC Performance make it stronger, cam it, forged pistons, springs, rods, injectors, zl1 fuel pump, the hole gambit. List goes on.
will get it tuned for 92 octane gas as well. Just to keep it simple on that side.
Old 10-09-2016, 11:09 AM   #12
Mrbowtie26
Mrbowtie26's Avatar
Drives: 2015 CRT 1SS 1LE
Sorry to hear that but hey it's an excuse for more power/reliability. Find out how much your going to pay to forge the bottom end. It may be worth it to get a complete short block and maybe up the cubic inches while your at it. Definitely a cam while your at it. I hope you have the fuel upgrades as well :-)
Mrbowtie26 is offline   Reply With Quote
