Old 02-10-2017, 12:27 PM   #1
Fit4Ink
Drives: 2010 Camaro 2SS/RS
LSA Blown LS3 Build
What's going on everyone!!! I finally pulled the trigger on a LSA blower and very anxious for it to finally get on island. Just want some insight on my build. Currently running a full bolt on setup with TSP 235/239 112LSA cam. Was wondering if I should get my heads ported and also if I really need to do a cam swap before blower install. I know I would leave some power on the table if I don't swap the cam which would be fine taking the fact later this year I will be doing a 416 stroker. Also contemplating on a gear swap to 3.73's?? Any insight would be highly appreciated. Thanks in advance
Fit4Ink is offline   Reply With Quote
Old 02-10-2017, 01:15 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Well, where do I start? Oh yeah, my build thread ;o).
I have a VVT SS1 similar to your specs and kept it. I do have ported heads and if you're pulling them, not a bad time to do them.
Lots to consider but that is a start. My build thread is loaded with all the changes I made including cooling options..
3:73 should be good for manual, 3:45s for autos...
Thanks
-Don
747 RWHP 794 RWTQ
Old 02-10-2017, 01:20 PM   #3
Fit4Ink
ok I will check out your build thread. thanks for the feedback
Old 02-10-2017, 01:46 PM   #4
hammdo
hammdo's Avatar
You can always pm me too..
There is a ton on my thread as I've done pretty much all the mods... I am an auto, but, you'll find a lot to consider...
Thanks for checking it out...
BTW, ADM has an 8 rib setup for the LS3 with an LSA if you need that...
-Don
747 RWHP 794 RWTQ
Old 02-11-2017, 12:01 PM   #5
hou30guy
Drives: 2011 convertible 2ss/rs
Lsa on a 416 with be choking it i bet
hou30guy is offline   Reply With Quote
Old 02-11-2017, 01:03 PM   #6
hammdo
hammdo's Avatar
Smokem has that setup and makes around 730 RWHP. M6... Car is a monster... I'll see if I can find his posts..
Edit:
716 RWHP 734 RWTQ
-Don
747 RWHP 794 RWTQ
Old 02-11-2017, 02:48 PM   #7
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
even if you dont swap the cam i bet you can still max out a stock short block with a blower. by max out i mean past the safe limits. sounds like you have healthy build in the future, good luck.
supergt99 is offline   Reply With Quote
Old 02-11-2017, 03:07 PM   #8
hammdo
hammdo's Avatar
100% correct on very likely maxing out the stock short block depending on what you add....
-Don
747 RWHP 794 RWTQ
Old 02-11-2017, 07:25 PM   #9
ADM PERFORMANCE
Drives: Anything I want
You need our 8 rib conversion for a 416.
ADM PERFORMANCE is offline   Reply With Quote
Old 02-12-2017, 01:17 AM   #10
Fit4Ink
My bad on the late responses... only why I want to go 416 because theirs no replacement for displacement. That's the way I look at it.. Ultimate goal is 2 hit at least 800whp on blower n then throw a 100-150shot on top of it...
@adm I was on the website yesterday I plan on buying something's from y'all 2 finish the build
Old 02-13-2017, 09:35 AM   #11
hazy
Drives: 2011 2SS/RS
if you're planning a 416, why not go with a bigger blower right from the start? I'd think that 750-800whp is on the top end of the capability for the LSA blower with a 416, but with a bigger capacity blower like a Whipple or Maggie, you could get there and not be on the limits of the blower itself..
Then again, take it for what it's worth...I am sure no guru, but I love learning about all this stuff bc I hope to have the funds to get to that power level someday!!
hazy is offline   Reply With Quote
Old 02-13-2017, 10:04 AM   #12
hillshooter
Drives: 2015 Camaro SS commemorative
Agreed from experience. The new motor will need a lot more blower.
hillshooter is offline   Reply With Quote
Old 02-13-2017, 10:55 AM   #13
Fit4Ink
Eventually I will go to a Whipple. Currently not in the budget right now
Old 02-15-2017, 07:36 PM   #14
ADM PERFORMANCE
You will love the car with 416 and Lsa .
We have done over 25 of this combo in both Ctsv and Camaro and not 1 complaint.
