Old 06-24-2022, 06:10 PM   #1
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
Ls3 overdrive balancer
What are my choices for overdrive balancer? I can only find one.
supergt99 is offline   Reply With Quote
Old 06-25-2022, 06:25 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Most folks do an under drive, why the over drive? Just curious.
Old 06-27-2022, 04:36 PM   #3
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Innovators West and Powerbond for sure have OD balancers. ATI may also offer one, i haven't checked them, but I've bought the first two over the years for both my Camaro and '07 Avalanche.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 07-11-2022, 09:24 AM   #4
Scott S
Scott S
Drives: 2011 Camaro 2SS
I run an Innovators 10% overdrive on mine with a 2.40 upper. Spin the blower as fast as possible.
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
Scott S is offline   Reply With Quote
Old 08-17-2022, 11:14 AM   #5
supergt99
supergt99's Avatar
you running stock short block?
