Old 07-10-2017, 04:16 AM   #1
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
thoughts on swapping to powerglide
like the title says. I'm tossing around the idea of swapping to a glide. will most likely be a bte with a 1.69 or 1.80 straight cut gearset. I will be swapping to a 3.23 rear over the current 3.73 rear end as well.
the reason for thiking this is I would be having the car caged very soon( getting quotes right now) and adding a parachute in prep for being legal. I anticipate the car to trap 155-160 range.
big cubic inch, big turbo(s) undecided on all of that at this moment in time...
thoughts?
ttshovel is offline   Reply With Quote
Old 07-10-2017, 09:43 AM   #2
CGbambam
Drives: 2011 Camaro 2SS
Do it, you wont regret it. boost + 2 speed auto, the car should fly.
Just remember go to with an aftermarket case for the trans
That's the same direction I am going towards since my rpm built 6 speed trans is starting to give out on me
CGbambam is offline   Reply With Quote
Old 07-10-2017, 11:16 AM   #3
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
I like my th400 but I don't think you could go wrong with a glide either
Kyle2k is offline   Reply With Quote
Old 07-10-2017, 12:48 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Do it.
Something happened the other night while datalogging to my car. I think the clutch let go (Triple RPS-no crunchy noises anywhere. Engine just revs and there is an occasional metal on metal squeal from the clutch/front of trans area) I've got other things going on so I haven't taken the trans out yet.
When I figure out what the deal is, I'm going to decide whether to rebuild the clutch/trans or auto swap to a 4L80 or TH400. Trans is already a Lvl 6 RPM.
Old 07-10-2017, 01:18 PM   #5
ttshovel
ttshovel's Avatar
yes! I'm looking at the bte racing powerglide, it's 2400hp rated and not badly priced. I don't think I'll have any issue getting rid of my 4l80 stuff
Old 07-10-2017, 01:22 PM   #6
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I know a guy who would be interested....
Old 07-10-2017, 02:03 PM   #7
bayarea408
bayarea408's Avatar
Drives: T
Jakes 4l80 i hear is one of the best and a great value. If my trans pops thats what im throwing in with a 3200+ stall.
bayarea408 is offline   Reply With Quote
Old 07-10-2017, 03:20 PM   #8
ttshovel
ttshovel's Avatar
that's what I'm running, their stage 3 trans
Old 07-10-2017, 04:44 PM   #9
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Why not a th400 if my 4l80 fails that's what I'm swapping to. They're cheap and very durable plus you'll enjoy that extra gear.
Trob85 is offline   Reply With Quote
Old 07-10-2017, 04:48 PM   #10
ttshovel
ttshovel's Avatar
weight and at that power level there's no need for the extra gear really. lots of guys are picking up et with a glide over a 4l80/th400 in strictly drag form.
