Old 05-17-2020, 05:58 PM   #1
Clubt
Clubt's Avatar
Drives: 2013 Camaro Convertible 2SS Summit
Looking to add a turbo kit
Looking to add a turbo kit to my 2013 Camaro
2SS convertible.
Was looking at the Turbonetics Stage 1 system.
Any advice appreciated.
Thanks.
Clubt is offline   Reply With Quote
Old 05-17-2020, 06:15 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Haven't heard of them. Around here most seem to gravitate towards AGP by i'm not a turbo guy outta just what i've seen in posts. AGP Huron and i think Hellion are good ones.
Greenhornet2 is offline   Reply With Quote
Old 05-17-2020, 06:17 PM   #3
Greenhornet2
Look in the classifieds there is usually a killer deal
Old 05-17-2020, 06:52 PM   #4
bayarea408
bayarea408's Avatar
Drives: T
AGP or Huron for twins, if you are set on a single Huron or the turbonetic stage 2. stage 1 chokes up real quick on our 376's
bayarea408 is offline   Reply With Quote
Old 05-17-2020, 06:56 PM   #5
caper
Drives: 2010 IOM 2ss/RS
if you want a CARB cert then youre limited. turbonetics stage 1 (then upgrade to 2 if you wish) - youll get the CARB sticker with stage 1, not 2. stage 2 will make as much power as the car will handle, stage 1 is limited for the reason mentioned above. twins are a good option if youre not seeking carb cert.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 05-17-2020, 07:45 PM   #6
Clubt
Clubt's Avatar
Caper,
Do i need a carb cert to be street legal in MA?
The Hellion twin looks nice. Is that a bolt on kit or do I need to modify more things on the car?
Old 05-17-2020, 09:20 PM   #7
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
You’ll need more to make it worthwhile. Fuel then a tune at least
joshnmn is offline   Reply With Quote
Old 05-18-2020, 08:21 AM   #8
caper
Originally Posted by Clubt View Post
Caper,
i unsure about the law in MA, but here in CA its pretty important if you get pulled over by the wrong officer. do yo need to modify anything else??? youre about to go down a rabbit hole here with no end. understand this...if you start increasing boost you will need to modify ALLOT of things on the car, because it will keep breaking things. starting with the engine lol, then clutch, trans, boost contoller, retune, and retune etc etc....if you keep boost at a modest level as it comes with the kit your likelyhood of doing all that decreases. BTW ive done all that and more lol. because im a greedy dick and ive sunk more money into it than it ever deserved. dont be like me lol.
Old 05-18-2020, 08:50 AM   #9
Scotty D
Drives: 2014 1le 1SS CRMT
Caper,
Don’t tell anybody but it’s all in the tune to pass emissions !!!!
Scotty D is offline   Reply With Quote
Old 05-18-2020, 09:14 AM   #10
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
Originally Posted by caper View Post
..... youre about to go down a rabbit hole here with no end. understand this...if you start increasing boost you will need to modify ALLOT of things on the car, because it will keep breaking things. starting with the engine lol, then clutch, trans, boost controller, retune, and retune etc etc.....
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 05-18-2020, 09:22 AM   #11
0331Marine
0331Marine's Avatar
Drives: 2012 SS/RS MN6
No disrespect, but it sounds like you don't fully understand what you're getting into. I suggest spending a lot of time reading about the different types of kits and what all goes into having a boosted car.
0331Marine is offline   Reply With Quote
Old 05-18-2020, 09:56 AM   #12
Greenhornet2
Caper,
I'm in CT, we don't have inspections just emissions. I know you guys have inspections but i don't think they fail you for modification as long as you pass emissions. A full kit should take care of everything you need to install it though it may or may not include a tune, that is the important part. As far as breaking things, if you drive it on the street and keep it somewhat tame you'll be fine. I haven't broken anything yet, but i have put slicks on it yet either. You will want to add at least rear trailing arms and toe links so you dont get wheel hop with the added power, wheel hop and shock is what breaks things.
