08-23-2012, 11:52 AM | #1 |
Drives: 2011 2ss blk on blk convertible Join Date: Aug 2012
4:11 richmond gears(how to fix speedo)
ok i got 4.11 on my 2ss, so how do i fix my speedo with out getting a programmer? my speedo is about 8 to 10 miles off on the plus side.....any help would be great...thanks
08-23-2012, 12:43 PM | #2 |
Drives: 2010 2SS-RS, IOM, M6 Join Date: Mar 2012
Tuner is the only way, its all electronic.
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter, DynoTech Driveshaft, E2X Catch Can . |
08-23-2012, 12:47 PM | #3 |
What copoz28 said, I used HP Tuners
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
08-23-2012, 12:52 PM | #4 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
+1 for HP Tuners. It's not going to be really cheap, because the tuner will have to use a license to change your gear ratio, regardless of what application he uses (EFI, HPT, SCT, etc)
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
08-23-2012, 01:06 PM | #5 |
so i ether i get a tunner and void my power train warranty or a i live with it...ok.thanks
08-23-2012, 01:08 PM | #6 |
need....more....hp
pretty much. The same issue of the speedo being off happens if you change tires. If you have an aftermarket radio, so use GPS to show you speed, you could use that, and same with the GPS units, some will show your true speed.
08-23-2012, 01:30 PM | #7 |
WICKDSS
Drives: 2011 1SS/RS IOM LS3 Join Date: May 2010
Just remember your miles on your odometer will rack up much faster now if you don't fix the speedo.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. |
08-23-2012, 01:33 PM | #8 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
And if you like to drive fast, your speed limiter will also kick in earlier too.
Always pays to look into these things before you get the work done. 4.11's are a great mod though.
NY5thgen.com
08-23-2012, 10:05 PM | #9 |
yeah the car pulls all the way from the bottom with the gears...they feel awesome... i have not gotten on it cuz i want to break them in first.......what speed is my speed limiter at?
i also put some super sports H&R springs and a cold air inductions intake..so far the car has responded great to all my mods.. i might just take the plunge and tune my car, and while im at it a cam would be in order..i really dont like the fact my miles would be racking up...thanks for the help.ill put pics up a little later |
08-23-2012, 10:39 PM | #10 | |
Perpetual Order
Drives: indeed Join Date: Jun 2012
08-24-2012, 12:08 PM | #11 |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
Just bite the bullet and do the tune (don't forget to get LT headers before a cam though). Your drivetrain warranty is toast with gears anyway (unless they don't figure it out).
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
08-24-2012, 06:24 PM | #12 |
08-24-2012, 07:15 PM | #13 |
WICKDSS
Well, enlighten us on how an odometer is accurate but speedo is not after a gear ratio change?! What am I missing here?
08-24-2012, 09:14 PM | #14 |
The odometer is run by the BCM, which receives its signal from the wheel speed sensors, not the transmission (which the speedo does). You can go so far as to unhook your speedo completely, and your vehicle mileage will still increase on the odometer. Tested and proven on my own car, multiple times, while I was figuring out how to wire speedo into a 4L80 swap
