09-06-2019, 09:17 AM | #1 |
Drives: Camaro 2ss Join Date: Feb 2019
Spark plug spacer
So I bought this car awhile back and I change the spark plugs right when I got it. I was getting a miss fire when I was at a high rpm for a little longer than normal. Read some forms that said to go to a tr6. I was changing them out at one of the spark plugs came out with a spacer on it and the tip broke... I got a magnet on there and got all the metal I could out. Is it time for a engine tear down? I bought a new spacer and I can’t figure out how to get it to set right. It’s letting the spark plug go way into it. I have it back out about the distance the other spark plugs are for now. What’s uall suggestions?
09-06-2019, 09:55 AM | #2 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
Someone stripped the threads and put in an insert? |
09-06-2019, 10:09 AM | #3 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
You probably have the wrong plug in there. It may be a tr6 but they should be conical seat not flat with a washer. Go buy the correct plugs
09-06-2019, 11:01 AM | #4 |
It’s called a Helicoil
09-06-2019, 11:01 AM | #5 |
Ouch
09-06-2019, 11:03 AM | #6 |
Thought you were referring to the gasket on a spark plug. I stand corrected.
09-06-2019, 11:04 AM | #7 |
Yes it was stripped and tapped. To fit that helicoil. I bought another one. I ran the tapper by hand and went smooth. I couldn’t figure out how to get the helicoil in there without the spark plug. When I use the spark plug it gets stuck on it so can’t figure out how to get the help coil to seal. I’ve put lock tight on it and have it sitting in the spot it should be but it definitely can still be tighten more....
09-06-2019, 11:25 AM | #8 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
I know its not ideal or even know what type of driving you do but that seems like a great excuse to upgrade the heads!
GJDM |
09-06-2019, 11:38 AM | #9 |
I drive it like I stole it everyday lol. Just not financially able to do that for a few weeks. Would buying used ones be a bad idea? Or any suggestions on new ones? I’m full bolt on cammed.
09-06-2019, 11:45 AM | #10 |
Could I just put a spark plug with the same threads and the helicoil?
09-06-2019, 11:45 AM | #11 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Parts stores will carry a helicoil kit. It comes with a tap for the head, and an insert setter. Run the tap through the head again to clean up the threads. Apply some loctite to the threads of the insert and use the setter. Let it dry for a few hours and put the spark plugs in.
The one I my toolbox is from Napa. It's called "Sav-A-Thread" Napa PN 770-3223 |
09-06-2019, 11:46 AM | #12 |
09-06-2019, 02:06 PM | #13 |
Drives: 13 IOM 2ss RS manual Join Date: Jun 2018
That looks like a Lisle spark plug thread repair insert to me.
What I would do if I was in your situation is figure out precisely where the insert needs to be located, depth wise, then make an install "tool" using a long threaded bolt (same thread as the spark plug) and a nut above the insert to stop the insert at the correct depth, then I would apply JB weld or similar product sparingly to od threads of insert and install into head. Allow the JB Weld to cure, then remove the bolt and install the plug. Be extremely careful to not glue the bolt and nut "tool" to the insert in the process. Probably a last ditch effort to save the head.
Rectangular Dollars will beat Cubic Inches
09-06-2019, 09:27 PM | #14 |
Pulled the plug again after driving a bit the tip was bent down and the helicoil is locked in place with lock tight so no adjusting it. Going to put a new plug in for now. Looks like I’ll be needing new heads.
Tags |
camaro |
