Old 01-08-2016, 12:21 PM   #1
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Reverse light upgrade? Bulb or whole unit...
Looking for some LED or brighter reverse lights for my 2011. I've searched the web for LED replacements but have come up empty.
Anyone have options?
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 01-08-2016, 12:40 PM   #2
Maverick1776
Drives: 2013 Camaro 2LS
I'd also like to know about this. The only solution I found is the one by oracle, but there is no way I'm paying $200 for reverse LED lights.
I need to check what bulb it uses. The hassle is going to be having to remove the rear bumper, unless its accessible from underneath.
Maverick1776 is offline   Reply With Quote
Old 01-08-2016, 12:49 PM   #3
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
You do have to remove the back bumper cover to access the bulbs for the reverse lights. Everything I've seen have been way morn that I wanted to spend, coming from AAC. Seems like a simple LED could be used for this application.
http://www.camaro5.com/forums/showthread.php?t=229051
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 01-08-2016, 01:45 PM   #4
Maverick1776
Thanks. I will definitely try this. I replaced all lights on the car with LEDs. This is the last one. Get rid of those ugly yellowish halogens. You really don't get much reverse light to work with from factory lights. So this upgrade will provide a safety measure as well.
Old 01-09-2016, 07:53 AM   #5
MoCamaro10
Drives: 2010 Inferno Orange Camaro
Just an fyi, I went this route and while it does help, the light output is still not the greatest. The look is definitely there, but if you have any tint, it won't be much improvement. I went ahead and bought a backup lamp that bolts on to the license plate instead.
MoCamaro10 is offline   Reply With Quote
Old 01-09-2016, 10:23 AM   #6
OmniCamaro
US Veteran
OmniCamaro's Avatar
The bulb is PH16W. That's what's stamped on the bulb. It's unfortunately not just a simple bulb we can replace. It's similar in design to a fog light in the sense it has its own little plastic housing with the nipples that you use to lock it into its housing. Seems a tad over-engineered for a reverse bulb.
Old 01-09-2016, 10:56 AM   #7
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 NPP BRM
Check these out.
http://www.carid.com/2010-chevy-cama...-25671147.html
Here's links for how to take off the rear bumper. First link also shows how to put back on.
1) http://www.lingenfelter.com/sites/lp....8%20small.pdf
Note - you don't have to do all the steps in this link, just the ones to remove & replace the rear bumper. Once you remove the rear bumper you have access to the back of the light housing, see pic of the light housing in step9. It's a one piece unit, you don't need to remove the rear bumper wiring harness ... just unplug the bulb socket, remove the bulb and replace it with the led bulb.
2)
camguynj is offline   Reply With Quote
Old 01-09-2016, 12:13 PM   #8
OmniCamaro
US Veteran
OmniCamaro's Avatar
THIS is about the best way to do it. Well, cheapest way.
Thanks for the link!
Old 01-10-2016, 10:06 PM   #9
SummoneR
Paul
SummoneR's Avatar
Hands down the best option.
http://www.automotivelightstore.com/...everseLED.aspx
I bought these a long time ago, and by far the best money spent on "cosmetic" changes to my car.
Before and after pics
Old 01-10-2016, 10:13 PM   #10
Camaro Dude
and SLEDGE
Camaro Dude's Avatar
Drives: '13 1LE, 2SS, NPP
^^^^Thanks for sharing
...but damn $200 plus shipping is steep!
Camaro Dude is offline   Reply With Quote
Old 01-10-2016, 10:26 PM   #11
SummoneR
Paul
SummoneR's Avatar
You're welcome. It is, but seriously night and day difference, no joke. They use 4 Large LED's in each unit that project directly out of the hole which is much smaller than the actual housing. The back up lights suck period. changing the bulb does not help much, this is a whole housing that aligns the LED to project out of the opening.
Old 01-12-2016, 09:25 PM   #12
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
The oracle kit is really the best route to ago in terms of effectiveness. Kinda just wish that someone other than oracle was making it, haven't had or heard of too many good experiences from their products. I made a thread asking the same question not too long ago, and a few people said that their reverse lights from them were actually behaving well, so I'd consider them. You could always warranty them should anything fail
Current: 2015 ZL1 M6, Rotofab, VMAX Throttle body, 2.55 Upper/8.86 Lower Pulleys, ID1050X, 1 7/8" Headers, 614rwhp/616rwtq
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
