Old 01-25-2020, 02:16 PM   #1
andyc098
Drives: 2011 Camaro LT
New struts and lowering springs
Well today I just installed new monroe shocks all around with new mounts, front and rear. Installed 1inch Phastek lowering springs, now I'm getting a bad squeak. Could it be rear sway bar links? I replaced the fronts. Also the washer on top under the hood; is there an upgrade for it? It seems like the washer isnt flush, maybe the noise could come from there?
Advice , help, please.
Thanks
andyc098 is offline   Reply With Quote
Old 01-25-2020, 02:17 PM   #2
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Did you tighten the suspension loaded with the cars weight?
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 01-25-2020, 03:58 PM   #3
andyc098
Just the front shocks, there's no way to tighten the rear under load right?
Old 01-25-2020, 07:36 PM   #4
Spec
Spec's Avatar
Drives: 2010 Camaro 1SS LS3
If you're wearing stock bushings, you need to make sure they're 'timed' properly.
That means loosening up some bolts after installing your lowering springs, then letting the car settle with full weight on all wheels, then tightening while weight is on said wheels.
If you don't do this properly, you risk squeaks and hops and uneven lowering. Search up 'timing your bushings' for more info.
The Silver Surfer
Spec is offline   Reply With Quote
Old 01-26-2020, 07:51 AM   #5
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Don’t forget an alignment!! You’ll eat some tires up if you don’t (ask me how I know). When getting aligned have the alignment tech do a once over on your work to make sure everything is tightened up properly.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
monroe, phastek
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
