Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Audio / Visual / Electronics/ Gauges / Nav
Old 05-20-2018, 05:47 AM   #1
Jburnham54
Jburnham54's Avatar
Drives: 2010 Camaro SS
wtb boost gauge and pods
need a gauge and some pods
Jburnham54 is offline   Reply With Quote
Old 05-20-2018, 07:24 AM   #2
Jburnham54
Jburnham54's Avatar
fuel pressure gauge too if someone has one
Old 05-20-2018, 01:50 PM   #3
Zspoiler
Zspoiler
Drives: 1979 Z-28 RS Camaro
For boost and fuel pressure gauges I would look at Auto Meter .That is what I run in my 1979 Z-28 RS Camaro .I mount mine inside my GlasTek 6" cowl hood,
Zspoiler is offline   Reply With Quote
Old 05-20-2018, 03:05 PM   #4
Jburnham54
Jburnham54's Avatar
id love too but your car looks badass with them, late models not soo much. if i go with a bigger cowl i would.
Old 05-22-2018, 11:13 AM   #5
gdheri
Drives: 2012 Chevy Camaro 2SS
I have singel gauge pod for steering wheel $50 ship
gdheri is offline   Reply With Quote
Old 05-22-2018, 11:17 AM   #6
Silver14
Drives: 2014 SIM 2SS
What kind of pod are you looking for? A pillar, steering column, vent, how many gauge openings, etc.?
If all you need is boost and fuel pressure, you may want to look for an Aeroforce Interceptor gauge to do both at once.
Silver14 is offline   Reply With Quote
Old 05-23-2018, 10:15 AM   #7
Jburnham54
Jburnham54's Avatar
the aero force goes off obd correct? idk how that woukd work as far as to get a fuel pressure reading, i have a fore fuel setup with no fpcm anymore. if thatll work id just go with a steering column pod but more then likely ill need a pillar pod for two
Old 05-25-2018, 11:30 PM   #8
Aldowelds
Aldowelds's Avatar
Drives: Turbocharged 408
I have the dual adm afr and boost gauge that goes above the steering wheel if interested. The afr needs to be resoldered to the board but you may be able to work something out with adm to get it fixed. Text me if interested 832-630-8231
Aldowelds is offline   Reply With Quote
Old 03-12-2019, 09:30 PM   #9
5th-gener
5th-gener's Avatar
Drives: 2010 camaro ss
NGauge for Sale
I have a brand new (still in box) NGauge for sale with defroster gauge pod all all connectors and SD card. Even comes with the connection piece for the suction cup mount if you decide to go that route instead.
(Picture for Reference of the defroster gauge pod)
5th-gener is offline   Reply With Quote
Old 03-24-2019, 10:26 PM   #10
Blown1LE
Blown1LE's Avatar
Drives: 2015 Supercharged Camaro 1LE
What is required for that to read boost ? How much are you asking for it ?
Magnuson Supercharged 2015 1LE RS/2SS. Texas Speed Stage 3 Blower Cam. DSX Aux Pump. e85 Flex Fuel Kit. BMR Suspension. On Instagram @wakeyourneighbors @Blown1LE
Blown1LE is offline   Reply With Quote
Old 03-25-2019, 06:18 AM   #11
charles71
charles71's Avatar
Drives: 2011 Camaro SS
Jburnham54. Not trying to muscle in or your deals here but I will take the single gauge pod for steering wheel from gdheri if you don't buy it. gdheri PM me.
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
charles71 is offline   Reply With Quote
Old 04-05-2019, 12:08 AM   #12
5th-gener
5th-gener's Avatar
It actually came in handy recently so I had to use it. Deciding to keep it now because of this. They are nice gauges, just didn't fit in the pod I originally got it with. Not at all what I was expecting. Went with a different pod from another member here and it looks and works much better. I would recommend the gauge if you're willing to lose your air vent on the driver side.
Texas Speed stage 2 blower cam
BTR Valve Springs/Retainer
GPI Rod Mod Intake Manifold
Corsa Xtreme catback
OBX long tube headers
E85 / ZL1 Fuel Pump ADM FPCM
MRR 228 wheels, 20x10 / 20x11
BMR Toe rods
Eibach 1" lowering springs
Eibach sway bars (Front, Rear)
CAI Cold Air Intake
Old 04-05-2019, 12:09 AM   #13
5th-gener
5th-gener's Avatar
Sorry for the sideways picture, not sure why it did that 🤔
BMR Toe rods
CAI Cold Air Intake
Old 05-14-2019, 05:07 PM   #14
David zeljuan
David zeljuan's Avatar
Drives: 2013 ZL1 M6
Any still available?
2013 M6
Roto Fab CAI - TSP 2"/ Corsa, Pat G Stage 3 custom Cam Nick Williams 102MM, Griptech Pulley (2.45) DSX Aux Lower (9.45) - 1300cc FID Fuel Injectors
McLeod RXT 1200
Trunk Tank w/ rule 3700
791/776 E85
YouTube: 3 Honks Away
IG: 3 Honks Away
David zeljuan is offline   Reply With Quote
