03-05-2019, 05:33 PM | #1 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Does oil pump have to come off?
For cam, timing gear, new chain, does the pump have to come off or no?
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
03-05-2019, 05:51 PM | #2 |
Drives: 2010 ss Join Date: Oct 2015
yes,to get the new chain over the crankshaft,pump must come off
03-05-2019, 06:37 PM | #3 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
yessir! crank snout protrudes through the crank gear, chain, and oil pump
Bone Stock |
03-05-2019, 07:48 PM | #4 |
weSS1LEy
Ok so good time to change the dampner to ls2 while changing to Melling is highly debatable
03-05-2019, 08:01 PM | #5 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
Yes indeed change your dampner to LS2 and install a Melling high volume oil pump.
Mr. Clean
03-05-2019, 08:07 PM | #6 |
weSS1LEy
I believe my shop voted against the melling
03-05-2019, 08:33 PM | #7 | |
C5.R timing chain, new crank & cam gear, LS2 damper and melling pump for me
Bone Stock |
03-05-2019, 08:35 PM | #8 |
the L99 cars are fine....its the LS3 ones that benefit the most
Bone Stock |
03-05-2019, 11:16 PM | #9 |
The Melling high volume oil pump will work just fine on the L99 or LS3 your shop doesn’t know what they are talking about. I had a Melling high volume oil pump on a L99 and LS3 Camaro and I never had a Melling high volume oil pump fail on me after 100K+ miles and track/street abuse.
Mr. Clean
03-05-2019, 11:55 PM | #10 |
weSS1LEy
Hmm 🤔 yeah I’ll enquire about it. I think they said they haven’t seen any stock pumps fail.
03-06-2019, 09:45 AM | #11 | |
Drives: 14 and 15 SS's Join Date: Feb 2018
Bolt-ons!
03-06-2019, 10:04 AM | #12 |
Not trying to steal your post but I have also been told to get a high pressure over a high volume pump due to high volume possibly draining the pan. Is this true?
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
03-06-2019, 08:27 PM | #13 |
weSS1LEy
Most of what I’ve read says high volume pump or stock. High pressure can cause stress on the seals. I’m no expert though. I see you have livernois parts... those guys are experts I’m sure they would know
03-07-2019, 08:27 AM | #14 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
I replaced my stock pump while I did my cam swap, but I just went with a stock replacement Melling M295 (not HP or HV).
If I went with either, I would go with high volume over a high pressure. In theory, adding more volume to the same area (oil channels) in the same amount of time should inherently raise the pressure some. I would not be terribly concerned about sucking an 8 quart pan dry with a HV pump. I didn't think stock pressures were bad though, so personally I didn't have any hangups about this pump. I went ahead and shimmed it when I installed it to try and help avoid cavitation in the high RPM range. So far no issues, but admittedly I don't have very many miles on it since this swap a year ago.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
