11-16-2022, 05:53 PM | #1 |
Drives: 2013 Join Date: Mar 2017
Modern spare solution
Have 2020 convertible with ru flats. Everything I've researched states that modern spare hasn't came out with anything for 2020 convertibles. Any ideas
11-16-2022, 06:30 PM | #2 |
Drives: 2016 2SS Convertible Join Date: May 2012
Their website shows compatible kits for your car. Coupes and convertibles use the same tires so the same kit works for both.
11-16-2022, 08:40 PM | #3 |
Drives: 2016 1LT 'Vert Join Date: Feb 2022
The only difference you'd need to worry about is that cars with the 6 piston Brembos require lager wheel 19" vs 18" for caliper clearance otherwise Coupe/convertible/2016-2023/I4/V6/V8 all use the same ModernSpare.
The website doesn't distinguish between coupe and convertible because those options are not critical to fit, only the difference for ZL1 to non-ZL1, not sure if this is why you're thinking that it won't work. There are a couple of threads out there already of people using a ModernSpare kit with Convertibles. |
11-17-2022, 08:03 AM | #4 | |
Hot Camaro
Drives: '20 2SS Convertible 6MT Join Date: May 2020
Here's the link to the non-ZL1 version: https://modernspare.com/product/2016...including-zl1/ |
11-17-2022, 08:32 AM | #5 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
When I take long trips I throw a spare in the trunk. I have no issues putting a 20" in the trunk. Doesn't leave a lot of room for anything else but it works. If you are running run flats then why worry about it.
11-17-2022, 09:38 AM | #6 |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
11-17-2022, 04:16 PM | #7 | |
Drives: Audi RS3 Join Date: Aug 2022
Pickles. |
11-17-2022, 04:27 PM | #8 |
11-18-2022, 10:34 AM | #9 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
If anyone needs the spacer for the modern spare (ZL1 or 1LE), I have one I’ll give you for free, just pay shipping. I have a modern spare and sold my ZL1 for a LT1, so the spacer is just a paper weight now…
11-18-2022, 02:53 PM | #10 |
Drives: 2021 camaro 1ls Join Date: Nov 2020
11-18-2022, 04:09 PM | #11 |
Drives: 2016 1ss camaro Join Date: Feb 2016
i have one too but not for free lol
11-18-2022, 04:19 PM | #12 |
Yes, I think they have, or will have a 19" version, but that, & the spacer, is not the main issue here. The main issue is where do you store your 20" 305/30x20tire after fitting the spare. Thank you to those who have responded to me previously on this matter, & some have said it will "probably" fit in the rear seat space (or the trunk?), but no-one is 100% sure that it will fit in either of these spots,...so I would ask, has anyone actually stowed a 305/30x20 wheel & tire in the trunk or rear seat space?
11-20-2022, 09:25 PM | #13 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
I too am curious, if the 305/30-20 will fit, before I order the Modern spare for the ZL1, I don't want to strap it to the trunk lid. I haven't purchased a low boy floor jack or installed my ZLoneaddons pucks yet, or I'd already have my wheels off and detailed and try rear tire an wheel fitment in back seat.
2023 ZL1 A10 Shadow Gray Metallic
