10-16-2023, 04:55 PM | #1 |
Drives: 2013 Join Date: Mar 2017
Fitment question
Is it possible to run a 245 45 20 on a 9.5 wheel. I've gotten yes and no answers
10-16-2023, 06:02 PM | #2 |
Drives: 2023 Camaro LT1 M6 Join Date: Dec 2022
From checking www.tirerack.com, it looks like 9.5" is widest wheel that they say will work w/245 width tires, so it should fit but is on the edge (hence why you may have gotten both yes and no answers).
However, note that 8.5" is a better fit for 245's, should be lighter weight, and there should be plenty of 8.5" x 20" wheels available to pick from (either from owners selling takes offs, wheel web sites,...).
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers |
10-16-2023, 06:04 PM | #3 |
Also - did you mean 245/40/20 ? That is stock Camaro tire size- 245/45/20 would be 3.6% taller in diameter.
10-16-2023, 07:20 PM | #4 | ||
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
BatMobileLT1 is also making a salient point; assuming that it isn't a typo and you actually want more sidewall to offset the crappy ride quality of runflat tires, you'll be much better off sticking with the factory 40 aspect ratio and get better non-runflat tires instead.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
10-23-2023, 06:13 AM | #5 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
The 245 section width on a 9.5" rim width is no problem at all. As Batmobile wrote, though, you need an aspect ratio of 40 instead of 45 because the 45 will give you a 28.7" tire diameter and that is too tall for proper fitment on these cars.
Matt Miller
2020 SS 1LE |
