05-08-2020, 12:01 PM | #1 |
Drives: 2010 LLT Join Date: Feb 2012
Timing Chain Idler Sprocket bolts
Good Morning everyone,
Been a long time since I posted, long story short. I'm doing my timing chains for the second time. The first time was around 100k and they lasted close to 70k, so I did the teardown for the second set. I believe my issue was related to the oil pump I could see my oil pressure dipping lower than normal for the past couple of months until the timing codes popped up again. After the first set, I was very religious about changing every 3 months or 5k miles on Pennzoil HM FS. I believe the Pennzoil made a difference as the first time I took the timing cover off the varnish and burnt oil build-up was horrible. This time around it was not too bad, some light varnish buildup with no chunks of burnt oil that I could see. Could be from the increased oil change intervals I honestly can't tell. The problem was in the process of replacing everything with a new timing kit from cloyes, I was torquing the timing idler sprockets I didn't even get to 30 ft-lbs. 1 bolt on the left bank seemed to have slipped slightly, I got nervous and thought I stripped the threads but looking at the bolt I seem to have twisted it as I could see the breaks in the metal but didn't shear it off completely. So I'm replacing those 2 bolts, went to the dealership to get a set of replacements and they were incorrect. They said that's what their system shows and they can't deviate from that. does anyone have the dimensions of the bolts? I feel dumb I didn't measure them before I tossed them in the trash. |
05-09-2020, 09:21 PM | #2 |
Banned
Drives: cheby Camaro Join Date: Aug 2019
I can't help you with the bolt sizes but I can tell you those bolts included in the Cloyes kit are known to break off completely while the engine is running. Be glad you never got that far.
Take the bad bolts to your local Fastenal store, they can help you. Good Luck What chain kit did you use @100k the 1st time you changed them? One more thing, be sure to soak those new chains in oil before installing them. By the time they get fully lubed from the vapor-splash oil in they engine they will be be worn hard. I also highly recommend you switch to a full synthetic oil and keep it full. You should have gotten easily 150k from a set of chains. The problem in these engines is they use oil. This in turn causes the chains to run dry because the only lube the chains get is from oil vapor and splash. Lower oil level = less lube on the chains. I keep my oil level 1/4qt above full, as it uses oil and gets to the full mark I add 1/4 qt. This works out to about 1/4 qt every 1k miles. I expect to get 200k before the chains need changing. Last edited by CamaroBarb; 05-09-2020 at 09:42 PM. |
05-18-2020, 12:53 PM | #3 |
First replacement chain set was Cloyes, it didn't come with any bolts at all. I was able to source the correct bolts from a better chevy dealer that knew what they were doing. Cost 12 bucks each but better for peace of mind. New Cloyes set looks exactly the same as the first also no bolts came with the kit, made sure I checked idlers before installing to make sure they weren't rusted out or damaged. I know Cloyes had issues with their idlers in the past I called the service number and they acknowledged this. They just told me to make sure it had 2 blue marks on the idlers and I should be good. Used all new gaskets but I did tear one of the vvt solenoid gaskets while installing the solenoid. I have placed an order for another set so I silicone this one in place until then. total job was about 15 hours from start to finish 2 days, I also cleaned the intake valves on both sides. Car runs way better than before didn't realize how bad it had gotten driving day to day.
02-24-2021, 06:11 PM | #4 |
Drives: 2010 Camaro LLT V6, 2018 Silverado Join Date: Sep 2020
Ok , update:
New Cloyes set made it 15k miles before the tensioner failed on bank 1. POS, I have several valves on bank 1 bent as well. have to take head to a machinest to check the valve guides and seats. I am having to order all new parts for the head and a new set of chains from a different vendor. Before everyone starts with the oil issue, I can tell you without a doubt I never ran low on oil. Oil was checked religiously on every full tank of gas and topped up when needed. Chains are fine from what I can tell, just the tensioner failed. Will be replacing with ac delco chains and tensioners, as this is my second cloyes chain kit failure and they refuse to warranty. |
02-25-2021, 02:27 PM | #5 |
Drives: 15SS Camaro Join Date: Dec 2020
What failed in the tensioner?
03-01-2021, 05:28 PM | #6 |
ok, I spoke a little too soon, Tensioner did not fail as far as I can tell. what broke was the crappy yellow plastic timing chain guide the puts pressure on the bank 1 timing chain. I ordered a leak-down tester to check how bad the valves are on that bank. I checked with a borescope camera and only saw contact on cylinder 1 exhaust valves but the valves seat all the way up. My hope is that the timing chain falling off the cam allowed the valve to roll the cam lobe out of the way before it seated itself. posting some pictures.
https://ibb.co/JnmdBTK https://ibb.co/fCSr51y https://ibb.co/DgcqKCy https://ibb.co/JF5f3g8 |
03-05-2021, 06:38 AM | #7 |
Thats a odd thing to happen.
03-08-2021, 11:02 AM | #8 |
No compression on cylinder 1, leak-down test failed with massive air leaks on the intake valves, not the exhaust. Failure now points to cam phasers on bank 1 are bad, I have a very slight play and a gurgling sound coming from both the intake and exhaust on bank 1. Bank 2 phasers are solid with no movement at all. The left head for sure has to get pulled, still thinking about the right one as the leak-down test was very good but of course, cant do a compression test until I put everything back together which would be too late. I was quoted 375 + parts for both heads, machining of the valve seats, and replacement of the valve guides if need be as well as soda blasting and cleaning of both heads. Car is in immaculate condition for being 10 years old so I can't just part with it yet. but I am super nervous about putting another cloyes timing set on there, the stationary chain guild that is on the main chain at the bottom also has the bottom of the plastic guild broken.
05-25-2021, 02:05 PM | #9 |
Drives: 2011 3.6 V6 RS Cabrio Join Date: Mar 2019
any update on your case? I replaced my chains with cloyes but still DTC P0008 remains.. I am suspecting from not using ACDelco chains.. What do you think?
06-07-2021, 09:17 AM | #10 | |
10-20-2021, 01:32 PM | #11 |
Oil pump was replaced, I am currently looking into an oil pressure issue as the timing rattle has popped up again after 10k miles on the brand new timing chain set. It only rattles at start up for a few seconds until oil pressure is built up, what's super weird is with the spark plugs out and rotating the engine by hand I can hear and see the timing tensioners retract and release on bank 1 and 2 almost like there is a vacuum in the oil system. I can confirm this is the sound i hear at start up for only a few seconds. I will be removing the pickup tube this weekend and see if its clogged, that's the only thing I can think of at this point. Oil pump has been replaced with a Melling M353 Oil Pump.
10-20-2021, 03:24 PM | #12 |
Drives: Classy Join Date: Apr 2017
Is your oil filter cap anti drainback valve working ? If not the pump has to re-fill the filter housing every time you start which might be starving other things.
10-20-2021, 03:41 PM | #13 |
how would I be able to check if its working? the oil filter cap is original and has almost 200k miles on it. could I leave it off overnight and take off the cap in the morning? the filter should still be wet with oil correct? this makes sense because the rattle is worse in the morning after an 8+ hour shutoff.
10-20-2021, 04:36 PM | #14 |
I don’t know how to check it as when you remove the cap the anti drain back valve gets released and the oil drains.
You might try pushing the valve by hand and add some oil to see if it drains or not. Holding the valve down should stop the oil from leaving the canister |
