Old 03-06-2016, 01:24 PM   #1
WFOMotorsports
WFOMotorsports's Avatar
Drives: 2013 Dusk Edition SS M6
Funny Tire Wear
On my 2013 Camaro SS both of my front tires are wearing in a very strange pattern. The insides and middle are wearing as expected, but the outside of both tires are wearing strangely. I've attached pictures below, the car is missing the front strut tower brace which my 2010 SS didn't come with but I'm now inclined to think this maybe the culprit due to the electronic power steering. Has anyone else experienced this?
WFOMotorsports is offline   Reply With Quote
Old 03-06-2016, 01:40 PM   #2
EWade
EWade's Avatar
Drives: 2015 Camaro LS
Looks more like too much toe in wearing the outer edge a bit more, if it feels like it's feathered one way that would mean toe in or toe out is out of where it should be. If the wear is even all the way around the tire on the outside edge, that would be due to excess positive camber. Would suggest taking it to have the alignment checked and aligned to specs.
15 LS in Blue Velvet
EWade is offline   Reply With Quote
Old 03-06-2016, 03:42 PM   #3
Synner
Drives: cars
How does a strut tower brace, or lack thereof, change your alignment and increase wear?
Old 03-06-2016, 04:12 PM   #4
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
alignment or another issue that causes this is low pressure.
justjoshin is offline   Reply With Quote
Old 03-06-2016, 08:27 PM   #5
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
Mine are doing the same thing. The tire pressure is correct and alignment is good. Had it checked shortly after making the following post.
http://www.camaro5.com/forums/showthread.php?t=440525
Low Saturn is offline   Reply With Quote
Old 03-06-2016, 11:35 PM   #6
WFOMotorsports
Thanks for the advice.
My tire pressure is perfect, I checked it today, will get the alignment checked for sure. I thought I had read about issues concerning the electric power steering without a strut tower brace somewhere before is why I ask about that. The toe does make sense, hopefully thats all it is. I have noticed the steering feeling a little too responsive to small input recently. I'll keep everyone posted to what I find when I find it.
Old 03-07-2016, 10:07 AM   #7
justjoshin
justjoshin's Avatar
You stated your pressure is correct but are you running P Zeros? The recommended pressure is for P Zeros is why I asked. If you have a different tire it may call for more pressure. If a tire has too little pressure it can cause the outside to wear due to flex in turns. I had this with the G-Max tires when I got them. Just trying to help out...
Old 03-07-2016, 10:43 PM   #8
WFOMotorsports
I still have the original tires on the car, it only has 17000 miles. That's good to know in the future though.
Old 03-10-2016, 04:01 PM   #9
Need4speed_motorsports
Need4speed_motorsports's Avatar
Drives: 2016 Camaro SS
looks like toe to me.
Need4speed_motorsports is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
