02-11-2021, 07:31 PM | #1 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Boost Gauge reading is off
I just installed a boost gauge and I don’t think it is reading properly. It drops below zero when driving all the way down to 20 and 10. When I get on it the gauge barely goes to 0. What’s up?
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
02-12-2021, 06:20 AM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Are you tapped into the right location? it sounds like you have a vacuum line.
02-12-2021, 11:05 AM | #3 |
Valkyrie14
Could be. My Hobbs, fuel regulator and gauge all are off a line on the boost actuator on the front of the blower.
02-12-2021, 11:45 AM | #4 |
Mine was always off. I went to an Aeroforce to read through the OBD2 since I had a 3 bar map and never looked back.
02-12-2021, 04:12 PM | #5 |
Valkyrie14
I already have my AFR plugged into the OBD. I looked at AEM’s boost gauge it has a pigtail but not sure what it plugs into
02-15-2021, 09:48 PM | #6 |
Valkyrie14
I did some re-routing of the boost lines today. I had a T on the hose that runs the boost actuator. The line is now right off of the stem that comes off of the blower right behind the actuator. No change in the reason on the glow shift boost gauge. Considering an AEM boost gauge.
02-16-2021, 03:45 PM | #7 |
Drives: Chevrolet Camaro Join Date: Mar 2020
Mine read the same while driving down the road but when I'm into it the boost goes to 7 which is where mine should be. I think my gauge is right and it's like it should be.
Sent from my SM-G781U1 using Tapatalk
02-16-2021, 10:02 PM | #8 |
Valkyrie14
My gauge never goes above 0. When I have my HP logging I see that I go into boost and my tuner says my blower is working. Before I sped $180 on a boost gauge I want to make sure I have it set up right. This gauge hasn’t gone above 0 not once, I was at about 5,000 rpms in 2cd gear getting on the highway and it barely got to 0. I’m pretty sure I was around 7-10 psi at that moment.
02-17-2021, 06:24 AM | #9 |
Still sounds like a vacuum line. Do you have pics of where everything is tapped in and T off?
I'm not as familiar with the LSA blower, but on the whipple, the actuator is vacuum operated ( before the rotors). I tapped my boost gauge from the plenum under the rotors. Sent from my Pixel 5 using Tapatalk
02-17-2021, 08:56 AM | #10 |
02-17-2021, 09:50 AM | #11 |
Valkyrie14
Here are pics of my setup. First 2 pics show my lines coming off of the blower. The upper stem is the line that runs to the regulator, Hobbs and boost gauge. The lower stem runs to the front upper inlet of the actuator. I have the lower inlet on the actuator is capped off. I noticed on the pics of the CTS V and pics I have seen on ZL1 there is a whole other sensor below the actuator that I don’t have. Please help me sort this out.
02-17-2021, 10:10 AM | #12 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Mine is tapped into the brake booster line. It was near perfect with the dyno. It's an AEM boost gauge. The glowshift are known to be slightly less accurate. You should be seeing boost psi once you are in it. Reading zero is likely from connected wrong spot.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
02-17-2021, 10:35 AM | #13 |
I have to agree that it looks like you are tapped into the correct location.
Have you been able to confirm that the Hobbs switch is actually seeing boost and working and that the fuel pressure is holding steady? Is it possible that the FPR or one of the fittings is bleeding off boost pressure? Is it possible the bypass valve is not closing and you aren't actually getting into boost? Process of elimination would say the gauge may be bad but it seems odd that the vacuum reading works but the boost doesn't.
02-17-2021, 10:41 AM | #14 |
Maybe a one way valve in the wrong spot?
