10-23-2013, 01:12 PM | #1 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2011
4L80 opinions and suggestions
Looks like I'll be forced to do the 4L80 swap sooner than I had planned. I've read great things about RPM, Jakes and Century.
Who do you suggest and why? What would be the best transbrake? What about the torque converter? I won't be using a Circle D so it would be nice to keep that option out of this thread even though many if you have had great success. Anyone with 1/4 mile passes with a 4L80 any regrets? What about daily driving? |
10-28-2013, 04:28 PM | #2 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
I did mine about a year ago. I have no regrets I hated the A6 hell you go 10' and you was in 2sec gear. Some don't like the long first gear with the 4l80 I love it. And in the 1/4 mile with the 3.91 rear gear made my best pass 10.57 @ 130.78 and the 60' not bad 1.53. I bought my harden parts from Jakes had some guys here in Tallahassee build it for me. I have had bad luck with mail order trans. If I had to buy one it would be from Jakes. Torque converter FTI their great to work with and I thank they have the best. As for driving with the 4L80 overdrive and lock up on the converter just as good as the stock trans
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
10-28-2013, 05:04 PM | #3 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
Don't overlook RPM Transmissions as they build incredible stuff and stand behind it like no other company. I will not have any other trans in my car but RPM. RPM is very personable and they are at every race and willing to help 24/7. Don't know anything about Century but have heard good things about Jakes but RPM in my opinion is the best out there.
10-28-2013, 07:20 PM | #4 |
Drives: 2010 camaro Join Date: Aug 2009
you are in texas it appears..jakes also in texas..i am running jakes and so far it is strong.can,t go wrong with rpm either..also have not heard much about century.. there are a couple different 4l cases, try toi get a newer one.. they are slightly smaller in some places...we had to do some frame boxing to get it in there correctly, others have not...this is due to the year of the 4l case
10-29-2013, 09:46 AM | #5 | |
Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi Last edited by MANNYS2SS/RS; 10-29-2013 at 10:24 AM. |
10-29-2013, 09:51 AM | #6 |
Drives: 2010 RS/SS Join Date: Dec 2010
RPM is my go-to builder, not just for beefy 4L60/70s but for 4L80e swaps as well. Very happy with the results and driveability!
10-29-2013, 10:31 AM | #7 | |
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi |
10-29-2013, 10:58 AM | #8 | |
10-29-2013, 11:02 AM | #9 | |
10-29-2013, 11:18 AM | #10 | |
Only thing I'm on the fence about is getting a built rear now or keep my fingers crossed hoping nothing happens with my stock. I'll think about it a bit more so I can make a decision I won't regret when ordering a drive shaft |
10-29-2013, 12:19 PM | #11 | |
10-29-2013, 12:27 PM | #12 |
I'll be going with FTI I'm just debating on single or multidisk.
10-29-2013, 12:53 PM | #13 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
We use RPM for all our cars including our record holding GTO with the 4l80.We also us3 the FTI. Converter s...If we can help you out with anything including your rear let us know.
10-29-2013, 05:57 PM | #14 |
I used a 96 case had to box for plug and massage right side to fit. FTI 3000 stall multidisc with lock up. Hey the PCM harness is the way to go no stand alone unit need with trans. I thank you want a 96 or older for case bolts in better. Also running stock rear and axles with 3.91 gear and slicks cutting mid 1.50 and low 1.60 60'. I'll run the stock diff until it blows. Don't wont to add weight I just cut it down to 3760lb from 4120lb
