02-06-2018, 01:16 PM | #1 |
Drives: 2016 Nightfall Grey Camaro 1SS Join Date: Nov 2016
AFTERMARKET SEAT HELP!!!
Hey everyone,
I just ordered some aftermarket seats for my 1SS. I'm pretty sure I already know the answer to the first part of my question, but will the airbag light come on when I disconnect the stock seat? Also, if it does come on, is there a work around to get the light to stay off? I've heard of connecting a 2 ohm resistor in series with the circuit but wanted to see if anyone has done this already. Thanks! ***EDIT*** So I installed the seats. I ended up going with two 6ohm resistors in parallel because its what I could find (total resistance in parallel would be 3 ohms) and they ended up burning up. They short circuited my car and I had to jump start it to get it back on. Insane pain in the butt. On the bright side the seats look great. Gonna try and reach out to my tuner and see if he can take off the airbag light.
LT4 Supercharger | Rotofab Intake | Ported Throttle Body | Stainless Works Exhaust | Flex Fuel
https://www.instagram.com/nightfallcamaro/ Last edited by nightfallcamaro; 02-26-2018 at 08:34 AM. |
02-06-2018, 06:12 PM | #2 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
02-06-2018, 07:15 PM | #3 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
02-06-2018, 08:24 PM | #4 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
You’re probably going to have to put a resistor in the airbag circuit to keep the light off. I don’t think it can be tuned out since its part of the SRS system
02-06-2018, 08:27 PM | #5 |
Drives: SS-6-SPD Join Date: Jan 2017
what i did on my subaru was put a resistor it worked for me ..
idk if it will work on the camaro https://www.rallysportdirect.com/par...BoCBeoQAvD_BwE |
02-07-2018, 08:09 AM | #6 |
02-07-2018, 08:30 AM | #7 | |
https://www.instagram.com/nightfallcamaro/ |
02-07-2018, 08:35 AM | #8 |
02-07-2018, 08:36 AM | #9 |
Drives: 2016 SS M6, NPP Join Date: Apr 2016
02-07-2018, 09:13 AM | #10 |
Typically when you unplug a seat belt connector and or a air bag connection and you start the car, you get a air bag light or a SRS light. That also throws a code and usually the code needs to be erased before either light goes off. Most SRS or airbag lights/issues require a dealer to correct the issue and or delete the code to shut off the light. Maybe Chevrolet allows you to disconnect battery, reinstall ( example ) removed seat, plug in connectors, , reconnect battery and presto.. no light and code is gone?? wishful thinking?
02-07-2018, 10:11 AM | #11 | |
For the OP, to turn of the airbag light he'll have to match the resistance coming from the plugs of the seats to the plug connected on the car. Second, he'll have to remove the passenger weight sensor bladder from his OEM seats onto the new seats. It's not an easy feat but it can be done. If he sticks a resistor that is too high, it can trigger the airbags. |
02-07-2018, 10:14 AM | #12 | |
02-07-2018, 10:33 AM | #13 | |
02-07-2018, 10:37 AM | #14 | |
Tags |
aftermarket, airbag light, camaro, resistor, seats |
