Old 04-02-2018, 05:17 PM   #1
Panda1LE
Panda1LE's Avatar
Drives: 2013 2SS/RS 1LE (6spd)
Faded hood issue
Does anyone know if there is a way to "revive" the flat black hood from a '13 1LE? I bought the car used and the hood is not in the best shape. Aside from re wrapping it, I was trying to figure out if there is any product out there that can help with the fading or whatever was used on it to cause the issue. Thank you
Panda1LE is offline   Reply With Quote
Old 04-02-2018, 05:22 PM   #2
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
Look on Adam’s Polish I’m sure they got something to help.
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 04-02-2018, 05:53 PM   #3
steakmaker
steakmaker's Avatar
Drives: '10 Camaro SS,Jeep Commander Hemi
"Back to Black"
Probably isn't fading,most likely they tried to wax it.There's a product by Mothers called "Back to Black",it's a spray coating for vinyl trim that restores the color,that might be something you'd want to try.
steakmaker is offline   Reply With Quote
Old 04-03-2018, 05:57 PM   #4
Panda1LE
Panda1LE's Avatar
Thanks for the responses so far. I think I have tried the back 2 Black without great results. Maybe I’ll try a small inconspicuous corner with it.
Old 04-04-2018, 03:56 PM   #5
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Hey,
Check out this thread.....I think it will help!
http://www.adamsforums.com/topic/134...vinyl-stripes/
Also here is a new product for your Matte Black hood.
https://adamspolishes.com/shop/exter...-detailer.html
Old 04-04-2018, 04:52 PM   #6
Panda1LE
Panda1LE's Avatar
Originally Posted by Adam's Polishes View Post
Hey,
thank you very much! I am just about to order a few hundred bucks worth of stuff from you guys. Maybe I will add this!
Old 04-04-2018, 05:41 PM   #7
Adam's Polishes
Thank You!!
Old 04-04-2018, 07:19 PM   #8
Panda1LE
Panda1LE's Avatar
Thank You!!
Dang it. The 15% off is over. I was just about to order quite a few things. Guess I have to wait now.
Old 04-05-2018, 06:55 AM   #9
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I have a 1LE, I clay bar my hood every so often. After claying and making sure the vinyl is dry, I that I go over it with some Adams VRT on their blue hex grip applicator pad and knock it down with a micro fiber towel.
VRT does leave a slight shine for a few days but then the vinyl returns to the flat look.
Coming up on 5 years of ownership next month and my hood still looks like the day I picked it up.
CamaroDreams76 is online now   Reply With Quote
Old 04-06-2018, 02:26 PM   #10
Panda1LE
Panda1LE's Avatar
Thanks a lot! Im am going to try this method
Old 04-22-2018, 05:02 PM   #11
Panda1LE
Panda1LE's Avatar
Here are a few pics so you all can see what I mean. At night or from far looks ok. But during the day or close up it looks bad. I’ll be trying the Adams matte spray I just got. Hopefully that works.
Old 04-22-2018, 07:00 PM   #12
CamaroDreams76
Photobucket.....you need to pay for 3rd party picture posting. So we see nothing.
Old 04-23-2018, 02:00 PM   #13
Panda1LE
Panda1LE's Avatar
I believe I fixed it now. I hope! Just figured out how to post pictures. On other forums I used to have to use photobucket and thought it was still the same procedure.
Old 04-23-2018, 03:28 PM   #14
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
ouch that looks rough, have you thought about rewrapping it with satin black?
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
