01-11-2011, 03:37 PM | #1 |
Drives: '69 SS Convertible Join Date: May 2009
Post your windshield washer bottle reclocation
I'm trying to decide on adding an ADM scoop or not. Obviously one of the issues is the washer bottle relocation. There are a handfull of solutions on the forum so I thought it would be good to have a single location for everyone to post what they did.
Post your pics and explanations and/or a link to a DIY thread you did or know of. Don't forget to include what you did with the pump if anything.
Build Journal |
01-11-2011, 04:11 PM | #2 |
Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
Caverman, ADM now has one. It consists of a bracket to which the plastic bottle attaches. Looks totally factory. Give Andy a call to get more details and perhaps a pic. I saw it installed in a car with Maggie and was impressed. Goes on driver side just behind the airbox. Good Luck
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
01-11-2011, 04:15 PM | #3 | |
Build Journal |
01-11-2011, 05:32 PM | #4 |
Drives: 2002 Camaro SS Join Date: Jul 2009
Interested as well, thinking about adding the ADM scoop also.
2015 1LE - CAI intake, TSP longtubes,
NPP, Futral Motorsports tuned, BMR 1"lowering springs, BMR trailing arms |
01-11-2011, 06:05 PM | #5 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Roto-Fab is also close to finishing their water bottle which also mounts to the left over stock bolt behind the box! Looks good so far! I just ordered my ADM scoop from Jannetty!
01-11-2011, 06:15 PM | #6 |
That Rotofab washer bottle looks like the best choice I have seen so far.
I did the scoop with a small bottle before the Rotofab was available. It was around $40 I think. I built my own bracket to mount the bottle so no cutting or drilling. I mounted mine right where Rotofab did. Get the scoop. Here is my install: The Bracket:
"Democracy Dies in Darkness" Last edited by Fraxum; 01-12-2011 at 07:59 PM. |
01-11-2011, 06:23 PM | #7 |
Drives: 2SS/RS CGM LS3 Join Date: Aug 2009
01-11-2011, 07:47 PM | #8 |
Cool....I hope more people post here.
And although this thread isn't just for me, having a Halltech is making it a little more difficult to find and solution. Most are mounting their W/W on the back of the heat shield but the Halltech's shield is so large there is only about 3" between it and the battery post. As you can see in this pic. I really like the looks of what Roto-Fab's new W/W looks like. Unfortuneately it won't work for me. Hmmm....now come to think of it, I guess I could always switch my heat shield with a Roto-Fab one and then get the W/W bottle. Guess I'll have to wait and see the other solutions and how much the Roto-Fab stuff is going to be.
Build Journal |
01-11-2011, 08:22 PM | #9 | |
"Democracy Dies in Darkness" |
01-11-2011, 08:29 PM | #10 |
Drives: 16 Camaro SS w/ Roto-fab CAI Join Date: May 2009
For those that haven't seen it, this is the Roto-fab W/W reservoir we are working on now. It is a tank molded specifically to fit the area pictured. For mounting, it uses the stud left exposed with most aftermarket intake systems along with a lower hole that already exists. No cutting, drilling or modifying to install this kit.
It will come with everything needed for installation including step by step instructions. We do plan on using an internally vented screw-on type cap instead of the stock cap pictured. By the end of the week we should have the mold modified to mold the threads necessary for the cap. We will post revised pics at that time. This reservoir should work with Roto-fab, ADM Performance and CAI induction intakes. It may work with others as well. |
01-14-2011, 08:35 AM | #11 |
Any more suggestions?
Build Journal |
01-14-2011, 09:06 AM | #12 |
5Th Gen (Craig)
I went with the ADM race intake and W/W bottle. Andy had a Camaro at his shop with that setup when I dropped my car off last Saturday and it looked fine.
2014 C7
01-14-2011, 09:08 AM | #13 | |
EDIT: NM...I see you said it's at ADM. When you get it back can you take some pics and post.
Build Journal |
01-16-2011, 06:27 PM | #14 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
mine
Similar Threads | ||||
Must post picture of a Chevy to win. | "prima"Donna | Off-topic Discussions | 74976 | 09-13-2013 11:33 PM |
Post Count Game.... | CamaroSpike23 | Off-topic Discussions | 1292 | 11-27-2012 10:26 PM |
Windshield Wiper Post Cover | SWING | USA - Texas | 26 | 09-26-2011 01:14 PM |
WASHER BOTTLE REMOVAL PICS ADM AIR SCOOP INSTALL | 1969to2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 11-08-2010 09:00 AM |
PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 11:00 AM |
