Old 02-10-2011, 08:12 AM   #1
Edrock
Edrock's Avatar
Drives: '10 Camaro 2SS LS3
275s on front stockers?
Hi all,
I've been reading around on the site and still have not been able to find some good pics of 275 width tires on stock front rims. I've seen all the warnings about width of tire vs. width of rim but am curious to see what it looks like on the car. I know somebody has done this so please post up some pics. I would love to see some 275 Continental Extreme Contact DWSs on the front stock rims but any brand will do for I suspect the visual should be close to the same. Also, have you had any issues with that wheel/tire combo? Noticed any uneven wear? difference in cornering better, worse, or no differnce for daily driving? What pressure are you running? Thanks for taking the time to post pics and answering the questions!!!
DT Shorties, Solo hi-flow Cats, X-pipe, resonator delete, Flowmaster Super-44s, VMAX TB, Stronger MAF, C.A.I. Intake with race scoop, and JRE Tune!
WOT is my happy place!!
Edrock is offline   Reply With Quote
Old 02-10-2011, 10:10 AM   #2
copper3000
Troy
copper3000's Avatar
Drives: 2018 ZL1 Camaro
I saw mtcwby's Camaro a couple of weekends ago and he has 275s on his stock front wheels. They look excellent! I'm definately doing it to my car. They have just the right amount of tire sticking out to protect the rim without being excessive. I was surprised at how great they look and he said they ride great too!
Sorry, I have no pics yet...
copper3000 is offline   Reply With Quote
Old 02-10-2011, 01:27 PM   #3
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
Wow I didn't know you can put stock rear tires on 20x8.
chopss is offline   Reply With Quote
Old 02-10-2011, 02:28 PM   #4
Edrock
Edrock's Avatar
Yeah, I've been after him to post some new closeup pics of the front but no luck yet. His pics I've seen so far in this forum show the car from the rear angle and you can't get a real good look at the front wheels. Hopefully in his spare time he will snap a few photos and post them up...(cough) hint! (cough) hint!...
Well ChopSS, just know there is no lifeguard on duty so you swim at your own risk. There are plenty of posts from very reliable sources that warn against it and even provide a chart with tire size recommendations (See "sticky" thread by Nine Ball on this subject in this forum). I just wanted to throw this disclaimer out there just in case. I'm still on the fence myself until I can see for myself so hopefully some folks out there will post up some good detailed pics and detailed accounts of issues and/or success. I have heard that 275s won't rub when the wheels are turned all the way in either direction. I also understand about the contact patch on the pavement being a possible issue due to the slight bulging of the sidewall caused by with 275 width on 8.0 inch rim. That's the part I want to see is how excessive OR NOT the bulge is with that combo. Cheers!
Old 02-10-2011, 04:57 PM   #5
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
What did he have for the rears?
Cam 427 is offline   Reply With Quote
Old 02-10-2011, 05:48 PM   #6
midnighter
Drives: nothing
I would go 265 on the front 8"s and 295 on the rear 9"s.
Old 02-11-2011, 03:00 AM   #7
COPZ
COPZ's Avatar
Drives: 2011 SYNERGY GREEN 1SS
What about just picking up 2 rear 20x9 with the same size rear tires and run that up front? That way you have the same size all the way around. Considering the new ZL1 will have 20x10 up front with a bigger tire then we have on the rear now, what would be the problem?
COPZ is offline   Reply With Quote
Old 02-11-2011, 06:59 AM   #8
Edrock
Edrock's Avatar
275 PZeros in the front, 305 PZeros in the rear. Here are his pics.
Attachment 189674
Attachment 189675
Attachment 189676
Old 02-11-2011, 08:47 AM   #9
copper3000
Troy
copper3000's Avatar
305s.
They were right at the limit of what I would try. They looked good.
Old 02-11-2011, 08:58 AM   #10
caverman
caverman's Avatar
Drives: '69 SS Convertible
Attachment 189674
Attachment 189675
Attachment 189676
Nice! So that is 275 on the 20x8 and then 305 on 20x9?
I actually like the slight bulge to give just a little protection from curb rash.
I'm thinking about buy some 20x9 to go on front. That way I can rotate tires to increase tire life....plus look a little better. Then I was going to take the 20x8 and put some 275 drag radials on them. Of course all I get about that is that the 275 is to wide for 20x8.
So...then the thought comes, what if I put 20x9 with 305 on all four corners.
Build Journal
Old 02-15-2011, 01:11 PM   #11
Edrock
Edrock's Avatar
...bump...
Seriously? Nobody has done this that would be kind enough to post pics?
ZL1 / CTS-V Brakes JusticePete Suspension / Brakes / Chassis 584 10-14-2021 09:33 AM
FRONT RADIUS ROD BUSH UPGRADE FROM EASY DIYer TO FULL RACE SETUP Info@PeddersUSA.com Suspension / Brakes / Chassis 4 08-25-2013 10:12 PM
NO MORE FRONT PLATE! SUPPORT NYS Bill A09426 LT1Jeep USA - NY / NJ / PA 17 05-04-2010 09:23 PM
APR Performance CF Front Wind Splitter w/Rods | IN STOCK + FREE S&H!! AJ@ECSMotorsports Exterior Parts & Accessories 4 05-03-2010 03:32 PM
Can i Run 275's in the front with no Rubbing? se7en Wheels and Tires Talk Sponsored by The Tire Rack 3 04-20-2010 11:07 AM
