#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Suspension | Brakes | Chassis
BeckyD @ James Martin Chevy
Old 01-27-2024, 11:02 AM   #1
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
2024 LT1 front brake pads part number?
Guys I'm seeing different results for 2024 front pads as there seems to be a slight change in the pad. They are no longer held in by pins, rather a torx screw.
Does anyone know the part number from GM or Powerstop?
24 LT1 M6 Sharkskin Metallic
havelegs is offline   Reply With Quote
Old 01-28-2024, 06:06 PM   #2
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
must be a secret, you'll probably have you take your brake RPO code to the parts counter at a dealership and have them look it up. I was looking for track pads and no one has released 2024 info that I could find. Luck has it mine 2024 are the same as the 23 SS1LE.
dpevans is offline   Reply With Quote
Old 01-28-2024, 07:51 PM   #3
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Do you have 6 Piston Brembo's? If you can PM me your VIN I can try to find out what RPO you have
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is offline   Reply With Quote
Old 02-04-2024, 01:47 PM   #4
turbojeep95
turbojeep95's Avatar
Drives: 17 Camaro lt, 22 Camaro LT1
You have the california compliant brake calipers. They are 4 piston brembos but get one's that fit a c8 corvette with the z51 package. I pulled these off rock auto so they should give you a good place to start.
-POWER STOP Z238009 Z23 Evolution Sport
-POWER STOP 178009 Z17 Evolution
-POWER STOP Z268009 Z26 Street Warrior
-Hawk DT60 HB926G.577
turbojeep95 is offline   Reply With Quote
Old 02-05-2024, 02:33 PM   #5
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
thank you
