08-01-2019, 12:43 PM | #1 |
Drives: 2014 Camaro 2SS 1LE Join Date: May 2019
Procharger
I've got a 2014 1LE roughly 36k miles on it. Currently is FBO, cam, p/p heads, spring kit and retainers, hardened push rods and e85. puts down 515 to the wheel and I'm entertaining the idea of installing a procharger D1SC. I know I need injectors for sure. Is there anything else y'all would recommend doing? The car will mostly be a daily driver, maybe hit the track or mexico a few times a year. I know FI is never really "reliable" but I'd like to maximize my chances and do it once and do it right. My goal would be 650-700 at the wheel. Thanks.
08-01-2019, 03:48 PM | #2 |
Drives: 2011 2SS/RS Join Date: Feb 2014
Fuel
there are a few options, but i think the big 3 are DSX, Fore, and Squash. Buy more than you need bc you''ll want more power sooner than you think. |
08-02-2019, 12:08 PM | #3 | |
I ended up getting a Fore Innovation triple pump staged, ID1050x injectors procharger D1x blower with a 3.85 pulley, TSP stage 2 cam 227/235 cam, DSX flex fuel kit, Holley Sniper Efi Intake Manifold, Monster Twin Disk Clutch,Holley Fuel Rails and a NW 102mm TB I went to a overkill to get 650rwhp but if I ever wanted to make more then I would need to upgrade the injectors and forge the block and upgrade the diff,axles,driveshaft etc
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
08-05-2019, 04:34 PM | #4 |
With my stated goals I should be good on stock bottom end, correct?
08-05-2019, 07:46 PM | #5 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Stock bottom end is a lot stronger than most think
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
