#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 04-20-2019, 06:54 PM   #1
stlrammer
stlrammer's Avatar
Drives: 2017 1SS Blue
Washer Fluid Leak
just noticed a puddle of wiper fluid coming from bottom of passenger’s front wheel well (below reservoir bottle). Still under warranty so no biggie but wondering if anyone has had this happen. Cracked bottle, line, fitting or pump? Cannot observe any abnormality inspecting from top side near firewall. Nothing wet at all. Just collecting puddle near rear passenger front wheel well below reservoir. I have 17 SS. Common issue? Hmm??? Thoughts?
stlrammer is offline   Reply With Quote
Old 04-21-2019, 03:01 AM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
are you sure its not water from the AC?
JCunningham is offline   Reply With Quote
Old 04-21-2019, 12:36 PM   #3
stlrammer
stlrammer's Avatar
Thanks JC. Liquid is washer fluid blue and the washer fluid tank is almost directly above the point of collection. Which forum is better? Thanks and Happy Easter.
Old 04-21-2019, 10:54 PM   #4
JCunningham
Drives: 2017 2SS M6
i was going to say general forum but it is fluids so your right to put it in here. i edited out that part in my post.
Old 06-03-2019, 09:28 PM   #5
stlrammer
stlrammer's Avatar
It was a cracked washer fluid tank and was replaced. First time I used sprayer turned out the washer pump shot craps so on my second trip the pump was replaced.
Old 09-06-2019, 02:02 PM   #6
neely_8
Drives: zl1 ABM A10
Did Chevy replace it or did you do it? I have to take mine out to get at my alky pump
neely_8 is offline   Reply With Quote
