01-09-2017, 07:16 AM | #1 |
Tri-County Camaro SWFL
1LEs major flaw?
I attended my first autocross event yesterday. My car is a DD and I've taken it to the drag strip numerous times and even raced in wannagofast 1/2 mile event. Well AutoX is much more fun.
Anyways I'm curious to hear opinions on what you think the most major flaw in a performance aspect for the 1LE. What I think is the biggest fail/flaw for this car is the seats. I found myself having to push my left knee into the door to stay in place.....And now my knee hurts it being the next day.
01-09-2017, 08:02 AM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Do you have the Recaro's seats? I did find these from the Road Course/Auto X Sub Forum.
http://angelwingstech.com/store/ Should help you from moving around.
Orange Krush II
01-09-2017, 08:04 AM | #3 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
Pull your seat belt tighter. Same thing happened to me
1LEs biggest flaw, M6... oh wait, after 35 years of shifting and now too old and too much rush hour traffic - that is my flaw HAHA. Your got one of the best cars GM has ever put out. You could always look into a 5 pt harness. Enjoy that beast!
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
01-09-2017, 08:22 AM | #4 |
Lets roll...
Drives: 14' Join Date: Jun 2014
The only flaw I can think of, would be that the car could have used a slight bump in power.
465 HP out of the factory would have been much better. Bet most people that have traded theirs in, would have kept them, had they had a bit more power. Not that it is not easy to make that power with minor mods, but would have been nicer having that as the baseline / starting point.
01-09-2017, 08:57 AM | #5 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
The seat situation is fixed with a good 4/5-point harness and frankly, very very few cars out there have excellent stock seats. The minute you start picking up serious speed, seats with stock belts become an issue.
For me, the weight is the biggest issue. A car this heavy chews through pads and tires and boils fluid too easily.
My thoughts on some things:
01-09-2017, 09:05 AM | #6 | |||
The angle wings definitely seem interesting. I've been keeping an eye out for Recaros on the classified section but I want 2SS Recaros seats. Quote:
I rode along with a driving instructor from Boca Raton that has a nasty S2000CR. He had the fastest run of the day. He helped a lot and gave me a few pointers. Also told me about the belt locking trick but it wouldn't stay locked. Quote:
01-09-2017, 10:23 AM | #7 |
Account SNAFU
Drives: 13 Tahoe 79 Scout II 15 1LE Join Date: Sep 2008
Find recaros or another race seat. I could be wrong but I think the recaros are the same regardless of 1ss or 2ss. I have recaros in mine and my first auto-x and track day were done with just the stock belt and I barely slid at all. Now I'm running a 6pt harness. My biggest complaint is the lack of cooling. Oil gets real hot real quick. But I am in the process of fixing that.
Sent from my campfire using smoke signals. |
01-09-2017, 10:45 AM | #8 |
A lot of people say the same thing when they autocross the car..door is killing my knee. I have Recaros and they are too heavy fyi..also wont solve issue..like these guys said you can try a harness. Maybe add some foam where your knee hits door?
It would have been sweet if they came from the factory with coil overs on the 1LE.
Car mods: never enough!
01-09-2017, 12:09 PM | #9 | |
Yes I use my heated seats in FL.
01-09-2017, 12:13 PM | #10 |
Account SNAFU
My 1ss are power both driver and passenger. But they aren't heated. Heated seats are nice
01-09-2017, 01:51 PM | #11 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Simple, it's weight.........
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
01-09-2017, 05:33 PM | #12 |
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS Join Date: Jun 2015
Bump in power. 460hp would have been nice. Besides that, weight is the obvious flaw. Putting dot 3 brake fluid that boils easy as hell was also a stupid idea.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold 2001 Camaro SS SOM M6- sold 1999 Firebird Formula A4- sold |
01-10-2017, 11:45 AM | #13 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Heated seats in a car with G2 tires you can't drive when its cold would be a waste . More power is what the 1LE needs.
OLD GUY FLYING FAST AND LOW
01-10-2017, 03:52 PM | #14 |
Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
More power and 6 piston front calipers.
