#Camaro6
AWE Tuning
Old 11-11-2020, 01:49 PM   #1
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
I was told this was normal. Your thoughts?
I brought my car to the dealer last week so I thought I would give an update on the ticking noise. A while ago I’ve noticed a loud clacking noise coming from the passenger side rear of the supercharger. This sound is heard best during the first 10-15 minutes of a cold start. The noise is so loud that you can hear it while sitting inside the car. Even after driving around, you can hear a faint tick. I can’t imagine that this is normal. Anyways, I was told by the dealer that this clacking noise is normal. I called GM and explained that I’ve been around other ZL1s that do not make this noise. They opened up a case and will be checking into the problem in a few days. What are your thoughts? Suggestions?
Video:
https://youtu.be/T7sZxrfTQw0
SSallday is offline   Reply With Quote
Old 11-11-2020, 01:54 PM   #2
RangerMan
"Camaro Style"
RangerMan's Avatar
Drives: 2011 2SS/RS A6 & 2018 ZL1
That doesn't sound normal. My ZL1 does not sound like that! Glad you have already called GM and got a case going! Hopefully they will figure it out!
RangerMan is offline   Reply With Quote
Old 11-11-2020, 02:28 PM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
HP Fuel pump?
Gunkk is offline   Reply With Quote
Old 11-11-2020, 02:52 PM   #4
HoldMyBeer
Drives: 2017 ZL1(Silver) - A10, Stock
That sounds like the blower lobes rattling. Possibly bearing going out in blower? Had same noise on my 2003 cobra and it was fixed under warranty. Ford ended up replacing my blower. Chevrolet needs to step up
2017 ZL1(Silver) A10
HoldMyBeer is offline   Reply With Quote
Old 11-11-2020, 07:13 PM   #5
SSallday
SSallday's Avatar
I was told that it could be a lifter or possible the coupler inside the supercharger. It makes sense that it would be the coupler because it sits in the back of the supercharger, which is where the noise is coming from
Old 11-11-2020, 10:08 PM   #6
Pupilbone
Pupilbone's Avatar
Drives: 2019 Crush ZL1 M6
Will second what RangerMan said. I’m no mechanic but that’s not ‘normal’. My ZL1 doesn’t sound like that, nor have any others I’ve been around. Good luck!
#SaveTheManuals
Pupilbone is offline   Reply With Quote
Old 11-12-2020, 07:38 AM   #7
Juiced1
Drives: 2012 2SS CAMARO 45th
Yeah, sounds like the bearings or the isolator are going bad. It probably needs to make a little more noise before they replace it. Just keep on spinning it hard and it'll get worse.
Juiced1 is offline   Reply With Quote
Old 11-12-2020, 08:02 AM   #8
RHD ZL1
Drives: Camaro ZL1
You could remove the supercharger belt and start the engine. If the noise is no longer there then it’s blower related. If the noise is still there then it’s engine related.
RHD ZL1 is offline   Reply With Quote
Old 11-12-2020, 10:34 AM   #9
SSallday
SSallday's Avatar
You would think they would take the supercharger belt off and start it. I guess that’s too complex for the techs. We will see what GM decides to do. Not sure what my other options are if they declare that it’s normal
Old 11-12-2020, 11:08 AM   #10
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Bring it to a different dealer. I’m not a mechanic, but can tell that’s not normal.
Chutzpah is offline   Reply With Quote
Old 11-12-2020, 01:31 PM   #11
SSallday
SSallday's Avatar
Spoke to the rep today. They are going to contact the dealer to see what’s going on. I’m guessing that they are going to send someone directly from GM to diagnose the issue
Old 11-16-2020, 03:48 PM   #12
SSallday
SSallday's Avatar
GM is authorizing a supercharger replacement. They said it may take up to a month to get the supercharger
Old 04-22-2021, 03:17 PM   #13
SSallday
SSallday's Avatar
The new supercharger was installed but it still has the same issue. I was reading up on the TSB for the fuel line check valve. Can this be the culprit?? I spoke to someone with a ZLE who has the same issue. The dealer replaced his fuel line but the issue returned a few days later. He brought it back to the dealer and they tested a few other things. They were able to narrow it down to the fuel system. After disabling something the fuel system during their diagnostic test, the noise disappeared. They gave the car back to him and said the noise was normal, which it’s not. Is it possible that the new fuel line is defective?? This noise is driving me nuts
https://youtu.be/UqBqKzQqbZk
Old 04-22-2021, 04:37 PM   #14
Wierd Harold
Drives: 2017 2lt rs
Go to a local auto store and buy a stethoscope,they are relatively inexpensive.Then start probing around .Had a set for years not used that much but gotten me out of a guessing game many times.
Wierd Harold is offline   Reply With Quote
