07-21-2014, 09:11 PM | #1 |
Drives: 2012 V6 Camaro and 2004 Gto Join Date: Oct 2013
04 Gto Wheels on Camaro?
I've got an 04 gto with nitto nt05 275s on the rear. Will these wheels bolt on to my Camaro no problem? I'm trying to avoid buying the expensive 20" drag radials or buying new wheels.
Performance - Solo High Flow Cats, Mrt2.0 axle back, CAI intake, and Vmax ported Tb
Everything Else - Flat black rally stripes, blacked out lights, black bow ties, black ss wheels, black caliper covers, black plastidipped exhaust tips, tinted windows, JL audio amp, 2 12" subs with custom box |
07-21-2014, 09:27 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
What's the bolt pattern and wheel offset?
07-21-2014, 09:29 PM | #3 |
Drives: 2016 1SS SW Join Date: Jun 2013
As long as they have a 5 X 120 lug pattern they will bolt. But the offsets may be all screwy, and the center hub may not be the right size. You'd need to buy hub-centric rings for that otherwise you'd be putting all the car's weight on your lugs. Lastly, you'd want to make sure the outside diameter of the tires are similar to your stock tires. If they are shorter or longer it'll throw off your speedo/odo.
I'd look up info for the GTO on a GTO forum to make sure before trying this out. Sent from my Nokia Brick using Tapatalk |
