03-23-2021, 06:43 PM | #1 |
Drives: 2017 Camaro Join Date: Feb 2020
Need advice...
Hello all.
I was wondering if the professionals here could help one of my family members. My son owns a 2010 charger. Wont turn on at all. Completely dead. Now. the last few weeks the car alarm has been going off on its own and we could not shut it off even with the alarm controller. The last few days my son says he would have to turn the key to on a few times before the car would start. This morning the car was doing the same thing. Which is when the key fob was placed into the key part to turn on...nothing would come on at all. no radio, no dash nights nothing. the only thing that would come on when key was inserted was the miles and the ringing sound when the key is in. I thought it might be the battery. so i tried jumping it and nothing. no lights...noting at all. I took battery to auto zone and the guy said the battery is good. so the question is what could it be? alternator? would the symptoms of a bad alternator be a completely dead car? any advice would be great. thank u
03-23-2021, 07:17 PM | #2 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
Does it have the factory alternator? If so, it is probably the alternator giving out, its 11+ years old if it is the factory unit, and also, it's a dodge...
03-23-2021, 07:39 PM | #3 |
Drives: 2019 Camaro SS M6 Join Date: Jan 2020
With the symptoms you describe, it sounds ignition related. I would go for a bad ignition control module or a bad ignition switch. You said the battery tested good, so that deletes the alternator idea. That's where I would start trouble shooting.
03-23-2021, 08:20 PM | #4 |
Drives: 2016 2SS Convertible Join Date: May 2012
Check both ends of the battery cables for loose or corroded connections. I would check voltage on the battery and voltage inside the car. It seems like you should have lights even with an ignition switch problem. I would also check under the hood and under the car to see if you have any damage from mice or other critters chewing on the wiring harnesses.
03-23-2021, 08:21 PM | #5 | |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2020 Colorado Join Date: Aug 2008
In all seriousness you have electrical power so that would rule out battery or alternator. Probably an ignition switch issue as someone stated.
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) |
03-24-2021, 08:58 AM | #6 |
thank u guys.
so just so i understand. yes i am pretty sure it is the factory alternator? so since the battery is good....it wont be an alternator issue? it should start even if the alternator is bad? how would i troubleshoot the ingnition switch? thank u!!
03-24-2021, 09:10 AM | #7 |
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi Join Date: Apr 2009
Alternator does not come into play until it is running. If the battery is known good, then I agree, there is a cable problem or an ignition problem. If it presents as stone dead, no lights, buzzers, chimes, etc., I'd look at ignition switch or more likely a problem with an aftermarket alarm install, wiring failure or damage. If it shows signs of life, but won't crank, could also be a neutral safety switch type of issue.
Good luck! |
03-24-2021, 09:38 AM | #8 |
thank u chef.
now all that comes on when i put in the key is the mileage and i can hear the chime. but nothing else comes on?
03-24-2021, 10:09 AM | #9 |
ok i think i found what might be the issue. just like yall mentioned. i want to thank my camaro family for all the help thx.
https://www.chargerforumz.com/thread....153422/page-2
03-24-2021, 10:21 AM | #10 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
The Chef brought up a good point. Is that a factory alarm or aftermarket? You mentioned having trouble with it. Maybe the alarm has a kill switch function that is causing you grief.
03-24-2021, 11:10 AM | #11 |
Hope it helps. Not a pro anymore but 35 years of experiences.
03-24-2021, 03:00 PM | #12 |
I thought about that. We have been having issues with alarm. It would go off on its own and would not go off. it would go off on its own after a while.
The key fob is really lose when we put it in. what yall think would be a good way of disconnecting the alarm to see if that is it?
03-24-2021, 11:26 PM | #13 |
Sorry. Not my Forte. I know they can be really involved on a modern car.
03-25-2021, 08:06 AM | #14 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Definitely something in the primary circuit of the ignition system.
Thread Tools | |
