The 2014 Corvette Stingray Forum
News / Blog Register Community Calendar Today's Posts Search
Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 11-17-2021, 07:19 PM   #1
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
APEX Wheels | Introducing Our Forged Sprint™ Line - Our Lightest Wheels
20" Group Buy Live, Click Here to Join
Our forged Sprint™ line was built to be extremely light while still offering a meaningful strength increase over our flow formed wheels.
➡︎ 10K ton forged 6061-T6 aluminum
➡︎ Stronger Sprint™ spec inner lip
➡︎ Side-milled spokes for reduced weight
➡︎ Massive brake clearance
➡︎ Independently tested and certified
Finishes
Fitments
10K Tons Of Pressure
Our new forgings weigh as much as 120 pounds before machining. To form such a thick blank we require special equipment capable of 10,000 metric tons of pressure. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure.
True Motorsport Blanks
Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch which gives us total control over the final product, resulting in exceptionally deep spokes and stronger designs.
Learn more our true motorsport blanks.
Side-milled Spokes
One of the most significant upgrades to our Sprint wheels is the addition of wider and deeper side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.
➡︎ 40-50% Wider
➡︎ 50-100% Deeper
Learn more about our wider and deeper side-milling.
A Stronger Lightweight Wheel
Our forged Sprint™ wheels are lightweight without the strength compromises found on typical lightweight wheels. First, we carved out as much material as possible, then we purposefully added one pound back to reinforce critical areas, creating a stronger inner lip and a higher load rating.¹ What’s the point of a lightweight wheel if it’s fragile?
Weight Optimized
We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a wheel that is exceptionally light without the strength compromises found on typical lightweight wheels.
Independently Tested
We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. We chose STL, an independent lab in Ohio, to test our Sprint™ wheels far above JWL standards, including increases in testing duration, impact drop height, and total load.
Learn more about our rigorous independent testing.
Tough Inner Lip
Introducing the Sprint™ spec inner lip, with a unique channel profile that makes it even stronger than our previous designs. So even though our Sprint™ wheels are pounds lighter than comparable flow formed wheels, the inner lip is stronger.
➡︎ 32% more reinforcement than our flow formed wheels.
Learn more about our Sprint™ spec inner lip.
Big Brake Clearance
From day one, APEX has been on a mission to build wheels that clear big brakes. Our new forged wheels are the product of everything we’ve developed over the past 10+ years, including an innovative high-clearance barrel design and vehicle-specific spoke profiles.
Deeper Concavity
Our new forgings were redesigned to create extra deep, concave spoke profiles. Their new shape allows us to make any profile, from flat to deep and everything in between. Each one is optimized for a specific application using 3D laser scans of factory and aftermarket brake kits.
Paintless Knurled Beads
Whether it's a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
Learn more about why our forged wheels have unpainted knurled beads.
Built for impact sockets
Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All APEX wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
Laser-Engraved Specs
As track enthusiasts ourselves, we know how frustrating it is to try to locate and decipher wheel specs that have been hastily hammered into the rim or become unreadable over time. With our new Sprint™ wheels, we chose to invest a little extra and laser-engrave the specs on the barrel, in plain sight, making them easy to find and read. (You’re welcome.)
APEX Forged Sprint Line Wheel Gallery
VS-5RS Gallery
EC-7RS Gallery
Learn More
VS5-RS / EC-7RS
Apex Wheels is offline   Reply With Quote
Old 11-17-2021, 07:20 PM   #2
Apex Wheels
Drives: Camaro Z28
18" EC-7RS Detailed Shots
18" VS-5RS Detailed Shots
Old 11-17-2021, 07:21 PM   #3
Apex Wheels
Drives: Camaro Z28
Crazy to think, but this is our first ever, in-depth video about any of our wheels.
Our engineering team put 2 years of hard work into our new Sprint Line and the forging dies that made them possible, so we were compelled to create a technical video that dives into the details. This video has a lot of great content our product descriptions don’t include. After watching, we’re confident you’ll truly appreciate why these features are so valuable.
If you're craving more content, this should quench your thirst.
Old 12-03-2021, 07:07 PM   #4
Apex Wheels
Drives: Camaro Z28
As we kick off the last four weeks of this Group Buy, we wanted to touch base to let you know that our first wave of production is right on schedule. This means we are currently on track to fulfill your orders in the timeframe outlined on the fitment table under the overview tab. Things could always change, but everything is looking better than expected currently.
As a reminder, if you have only expressed interest and have not pledged, you're not officially a part of the deal to receive wheels. With nearly 400 members interested, some popular fitments and finishes will sell out in the first production run. We’ve already placed a restock order and it should be here pretty quickly, but we have not decided if we will cancel backorders or if we will allow late participants to get the discount and receive wheels from the second shipment. Be sure to come back and submit your pledge to lock in your order now to avoid the rush that always happens in the final week.
Technical Note
As a group of track enthusiasts and racers, we understand how frustrating it can be to bend a wheel in pursuit of a PB or podium finish. Whether you find yourself 4 wheels off track on a safari excursion or creating your own driving line jumping treacherous berms, wheels are put through a tremendous amount of stress and abuse in the process – sometimes simply being forged isn’t enough to avoid bends.
To mitigate this, our engineers made a concerted effort to reinforce the inner lip of these motorsport wheels and created our stronger, Sprint™ Spec inner lip design. If you haven’t already, we recommend you read our technical writeup on our Sprint™ Spec inner lip.
Blog: MEET THE STRONGER, APEX SPRINT™ SPEC INNER LIP
Old 12-08-2021, 07:06 PM   #5
Apex Wheels
Drives: Camaro Z28
When Function Meets Form
As wheel specialists we understand that, when it comes to reducing weight and increasing stiffness in wheel spokes, there is a big difference between functional and aesthetic side milling. Instead of milling a few negligible millimeters of depth just to look cool, our engineers optimized our new motorsport blanks to create narrower yet significantly deeper spokes, with deeper side milling that is nearly 50mm wide on some wheels. The result is a stiffer “I” beam-spoke shape that also showcases a stunning aesthetic. If you haven't already, we recommend you read our technical write-up on our deeper and wider side-milling.
Blog: HOW DEEPER AND WIDER SIDE-MILLING MAKES WHEELS LIGHTER
Old 12-15-2021, 07:18 PM   #6
Apex Wheels
Drives: Camaro Z28
Get To Know Our 50% Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, or a club racer pushing the limit for a podium finish, mistakes happen, and parts can get damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our goal was to make replacing a damaged wheel with a brand-new one much more appealing than ignoring the problem or performing any questionable and compromising repairs. This program will also help keep damaged wheels from being passed on to unsuspecting enthusiasts via the secondhand market.
Discounted replacements are ideal for customers who accidentally damage their wheels with curb rash, bends or dings from potholes, berms, road debris, and off-track excursions. Complete destruction of a wheel from serious accidents also qualify, including tire wall or barrier impacts, contact with other racers, or any accidents resulting in a total loss.
All pledged members that participate in this Group Buy would be eligible for this replacement program. For more details, be sure to visit our website here.
Old 12-17-2021, 07:08 PM   #7
Apex Wheels
Drives: Camaro Z28
Production Update
Batch 1: The first batch of wheels is arriving at our warehouse in the first week of January. We are on track to fulfill these wheels in January as planned. We will continue to notify everyone once orders begin to ship out.
Batch 2: Production is being buttoned up, and we are on track to ship orders out in March without delay. We do not expect any delays at this time and will update everyone once production is completed.
Reorder Production: Due to the success of this deal, we are already producing additional wheels to arrive a few weeks after the 2nd batch.
Video Q&A With Our Founder
Our Marketing Director sat down with our CEO to discuss the in’s and out’s of our new Motorsport Blanks. Check out our latest episode of APEX Tech Talk to learn about the difference between our motorsport blanks and typical “street” blanks.
Old 01-04-2022, 07:37 PM   #8
Apex Wheels
Drives: Camaro Z28
Thank you to everyone who participated in the Group Buy! It is now closed and we will be in touch will all who ordered. Have a good one!
Old 06-27-2022, 02:55 PM   #9
Apex Wheels
Drives: Camaro Z28
Cory - Fitment Specialist | Phone: 925.245.0773 | experts@apexraceparts.com
Website | Instagram | Facebook | Blog
Old 09-28-2022, 06:57 PM   #10
Apex Wheels
Drives: Camaro Z28
You asked, we listened. Our first ever 20” wheels are now available!
VS-5RS
Our popular VS-5RS design is back and bigger than ever before. Our all-new 20” VS-5RS fitments are APEX’s first-ever foray into 20” diameter wheels and we couldn’t be more excited for their arrival. While we’ve historically focused on compact and efficient fitments that clear massive brakes with smaller wheel diameters, 20” wheels have become a necessity as the cars we support grow larger and more powerful with each successive generation.
We also recognize the massive contingent of our customer base and enthusiast community that appreciates the unmatched performance features and support APEX provides while preferring the aesthetics of larger diameter wheels. Careful optimization of these wheel designs by our engineering team has helped to minimize the weight penalty of a larger diameter wheel while our already stellar brake clearances have significantly improved. These new fitments cover a number of Corvette models representing the beginning of our 20” wheel lines. Help us and the Gang unlock the max discount by joining this Group Buy.
The Details
Fitments
Many C6 and C7 owners love to run 20” rear wheels for that aggressive look and our new Forged Line and the VS-5RS, in particular, was the ideal option for 20” fitments and production. Since the 19” wheels have already proven to be incredibly popular on this chassis, we are pumped to have another diameter and all new fitments to add to our Corvette lineup. 19” front wheels are available in this deal.
Dates:
This deal is now live and locks on 10/27/2022 at 11:59 PM Pacific Time. The wheels are currently scheduled to ship out by the end of December for Corvette fitments. Visit GangUp.com for more information.
Discount: Up to $500.00 off plus Free Shipping*
Join The Gang
To streamline pledging and fitment selection, we use GangUp to track interest and pledges. This system lets you commit at your preferred discount level and removes the old-school headache of forum threads and email chains as a Group Buy heats up. Watch the video below to learn how GangUp works and how to pledge.
https://youtu.be/sFQXUSehYrg
These Group Buys depend on the community to succeed, more pledges mean deeper discounts and more competition for popular fitments and finishes. Make sure you pledge early to get the best possible allocation for your preferred set of 20” VS-5RS wheels.
More Info
VS-5RS
Gallery
A Fitment For You
We know what fits. From direct bolt-on to aggressive track day fitments and everything in between. We've tested extensively to save you the trial-and-error.
Click to view our fitment guides
Questions?
Call: 925-245-0773
Email: expert@apexraceparts.com
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST
*Free Shipping: This Group Buy offers free shipping to the 48 mainland US states. Buyers who have products shipped to Alaska, Hawaii, APO/FPO, and International destinations will receive a discounted shipping rate.
