12-06-2022, 12:03 AM | #1 |
Drives: 2017 Camaro SS Join Date: Nov 2022
Loud rattling sound coming from rear of car after Cora Extreme Exhuast
hey all, new to this website but i'm having an issue with my car hoping someone can help. recently just had a corsa extreme exhaust installed with texas speed headers, got the proper tune but noticed on cold start & with i give it gas below 1500RPM there's this awful loud, rattle/ banging noise. took it back to the shop and was told that maybe i have a loose exhaust valve? i have provided a link to my cold start, any help would be much appreciated http://youtube.com/shorts/m3-JcsPUelw?feature=share
12-06-2022, 03:07 AM | #2 |
Drives: 2017 2SS F1FTY Join Date: Feb 2020
I would take it back to the whomever you had do the install and ask them to figure it out. Even if you have to pay them.
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
12-06-2022, 06:02 AM | #3 |
Drives: '10 Equinox LTZ Join Date: Jul 2011
I wouldn't trust a shop that told me I had a loose exhaust valve. Find another mechanic and get it on a lift.
12-06-2022, 09:13 AM | #4 | |
Drives: '16 2SS M6 Join Date: Aug 2019
It should be easy to locate that from under the car.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
12-07-2022, 12:59 PM | #5 |
12-07-2022, 02:10 PM | #6 |
Drives: 2019 RS Convertible 2.0T Join Date: Nov 2022
That sounds a little extreme, but sometimes the mufflers will rattle as they are breaking in. I’ve had that with previous exhausts I’ve installed on my own cars and thought something was loose. Would check and everything was good and tight then it would go away in a couple days.
12-07-2022, 03:14 PM | #7 |
NPP valves are at the exhaust tips, AFM valves are in the pipes (if it even has them).
David
12-08-2022, 11:36 AM | #8 | |
12-08-2022, 03:19 PM | #9 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
I wasn't going to say anything, in my case rattling was the X-Pipe settling against the Cross Member brace. Its an easy enough fix and my shop did it for free as they did the initial install. They also said all Camaros have that issue with the X-Pipe settling and rattling against the Cross Member Brace
I did watch your video and it doesn't exactly sound like the same issue I had. I am not sure if that is applicable in your build I didn't see you specify an X-Pipe upgrade.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
12-09-2022, 01:21 PM | #10 | |
12-09-2022, 02:31 PM | #11 | |
High Pressure exhaust flow. As I'm no expert would need to be defined for me. At first guess, it could be an exhaust leak like others have said. Rattle is Rattle, it can have different tones, and sounds. In my case the rattle literally sounded like metal bouncing on metal with the right RPM levels.
01-18-2023, 10:14 PM | #12 | |
01-18-2023, 11:34 PM | #13 |
Drives: 2020 Camaro SS 1LE | Satin Steel Join Date: Jan 2022
It’s probably the exhaust rubbing against the tunnel brace. When I installed mine, it rubbed and it was LOUD.
01-19-2023, 08:05 AM | #14 | ||
Had same issue when I had my X-Pipe installed. My shop shimmied the brace and I never had the issue again.
Tags |
corsa exhaust, corsa extreme, loud, rattle |
