Old 02-05-2014, 08:56 AM   #1
infernometallicSS
infernometallicSS's Avatar
Drives: 2012 Camaro SS Best Run - 10.93@125
Blow Down Tube??
So I have a nitrous outlet system and mounting plate.
Has anyone done a blow down tube in that location? I would like to see what you all have done.
I was thinking of using 8AN braided steel line instead if the big tube that it comes with, just place a bulkhead on the underside of the car to eliminate the chances of it moving.
I feel that's just as safe. I would like to hear everyone's thoughts and see some pictures if you have any.
Thanks.
infernometallicSS is offline   Reply With Quote
Old 02-05-2014, 09:58 AM   #2
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Is a blowdown tube required if the bottle is in the trunk? Thought it was only needed if the bottle was in the cockpit.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 02-05-2014, 10:02 AM   #3
striker1703
striker
striker1703's Avatar
Drives: 2010 Camaro 2SS
Getting ready to go racing I see .
I needed a blow down to pass tech @ Wildhorse when I went and mine was towards the passenger side in the truck .
striker1703 is offline   Reply With Quote
Old 02-05-2014, 10:59 AM   #4
infernometallicSS
Trying to get ready. The DA an hour ago was like 863 or something. That's crazy for out here.
Old 02-05-2014, 01:01 PM   #5
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Attachment 597238
Thanks.
Yes you can use the braided line in place of the hard line and just remove the plastic plug ans run the line through it, no need to drill a hole.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 02-05-2014, 07:50 PM   #6
infernometallicSS
I did my blow down tube. I used braided steel line and I utilized an existing hole in the battery compartment. I then did a bulkhead fitting to secure it all in place.
Old 02-09-2014, 12:01 AM   #7
BLACK10
BLACK10's Avatar
A blow down vent is always a good idea to have incase bottle pressure exceeds the burst disk rating. Nothing worse than a car full of NO2 gas!
