01-22-2021, 04:09 PM | #1 |
Drives: 2013 Join Date: Mar 2017
2020 RS tire question
Running the original 245 40 20 now. Like to go wider without rubbing issues. Any suggestions or opinions is appreciated
01-22-2021, 04:46 PM | #2 |
Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Check out the website TireSize.com for alternate sizes for your Camaro. You can compare different sizes with the original size in the site. Hope this helps you.
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
01-22-2021, 05:49 PM | #3 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
You can only go so wide on the stock rim before decreasing overall performance, wear, and safety. Also have to consider overall diameter as well since that could throw off the speedo
01-22-2021, 06:34 PM | #4 |
Drives: 2021 LT1 Join Date: Aug 2020
255 is likely the widest you can fit on an 8.5" rim... I'll be swapping out the run flats for a 255 on my LT1 soon.
01-22-2021, 06:39 PM | #5 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
If you prefer the same width front and rear, you may need to get comfortable with spacers because the offsets are different. For example, you could go with 20x10 wheels with offset around 40mm and then use ~15-18mm spacers up front. You'd need longer studs for that, which is not a big deal. Then you could use 285/30/20 tires front and rear. For that matter, you could find two pairs of stock SS rear wheels and use spacers on the fronts, with the 275/35/20 tire fitment. You have lots of choices, but you really need to plan new wheels.
Matt Miller
2020 SS 1LE |
01-22-2021, 08:12 PM | #6 |
376 cubic inches of fun
The safest way for you to go wider is to order a wheel and tire set for the SS from tirerack.com.
That way, you will be assured of the correct width and offset of the rims. |
01-22-2021, 08:33 PM | #7 |
So I guess the SS takeoffs would be the best bet. There are a few locally for sale. Thanks
01-22-2021, 10:36 PM | #8 |
Drives: 2018 Camaro RS 3.6 A8 Join Date: Jun 2018
01-22-2021, 11:54 PM | #9 |
OP what is your goal here? Are you just wanting a slightly wider look or what exactly?
01-23-2021, 03:55 AM | #10 |
Just a wider look. Bettsr looking stance
01-23-2021, 08:13 AM | #11 |
Have you considered running some spacers instead. I'm not usually a fan of these, but it would be a cheaper alternative to give you a slightly wider look
01-23-2021, 09:33 AM | #12 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
It sounds like you want a wider tire. If looking for a good all season I recommend the Michelin AS 3+ in the factory SS size on a stock SS rim.
01-23-2021, 09:48 AM | #13 |
Drives: C6 Vette Join Date: Jul 2008
Is the SS tire the same diameter as the LT1 so the speedo isn’t thrown off with the A10? What drag radial choices does the LT1 have all while making no changes to the stock tune?
01-23-2021, 09:52 AM | #14 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
You can go 255/285 on stock SS wheels, anything beyond that can be dicey. Spacers are an option, but do you want to screw up the suspension geometry with big ones just for stance? Those safe and small 3-5 mm ones won't give you much of a wow factor.
If you feel adventurous, though, KingLT1 here did 305 rears with Nitto 555R on stock SS wheels: https://www.camaro6.com/forums/showthread.php?t=541363
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
