02-27-2024, 02:43 AM | #1 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Caddy lifter preload
What are you guys that run these lifters running for preload? .100 or less?
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
02-27-2024, 05:08 PM | #2 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I try to get in between .060-.080
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
02-28-2024, 06:50 AM | #3 |
GPI Sales Consultant
They are pretty happy with anything like you would do with a stock LS7 lifter. We target anywhere from .050" to .130" depending on the application. If it's tight on PTV, we'll lean towards the light side, if that isn't a concern you can put a little more to them to reduce the room for squish. The lifter itself doesn't really care too much where in the preload range it is, as long as it's not bottomed out, or seeing lash when everything is warmed up and grown.
Got a question about a GPI product? Feel free to shoot me a message! |
