#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Suspension | Brakes | Chassis
AWE Tuning
Old 12-01-2016, 10:00 PM   #1
F1FTY
Drives: 2018 ZL1
SS Spring Rates - SS/1LE/BMR/Eibach/Hurst
I'll be continually updating this post - best to bookmark
Non-MRC SS Rates: 137 lbs/in (Front) 577 lbs/in (Rear)
Hurst: 150 lbs/in (Front) 420-550 lbs/in (Rear)
Eibach Rates: 160 lbs/in (Front) 121-691 lbs/in (Rear)
1LE Rates: 178 lbs/in (Front) 539 lbs/in (Rear)
BMR Rates: 175lb lbs/in (Front) 640lb lbs/in (Rear)
Eibach rear springs must be progressive.
Hurst are linear front and progressive rear.
BMR is 100% linear front and rear.
Factory SS and 1LE are basically linear
Ride Height (measured from center of wheel well straight down to center of wheel):
Factory SS (MRC): 15.5" Front / 15.6" Rear
Factory 1LE:
Eibach (Non-MRC): 14.5" Front / 14.5" Rear
1LE Spring Rate Front
1LE Spring Rate Rear
F1FTY is offline   Reply With Quote
Old 02-18-2017, 04:34 PM   #2
tecmec
Drives: 2016 2SS
Anyone? I'm curious too. Is this information not out there? How are people choosing new suspension without knowing spring rates?
tecmec is offline   Reply With Quote
Old 02-18-2017, 07:53 PM   #3
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
It's out there, but you have to check with the various suspension manufacturers. For example, when they say x part is 60% 88%, etc stiffer. They know the rates.
Some of the sites will post that as well. If you know how much percent stiffer it is, it'll give u a starting point to do some math.
I don't have a 1le model, but it's what I've donever with the LT and Ls models in the past.
Many on forums aren't as Tech oriented in decision. Moreso many people make their choices off visual pics and seeing how far spring lower various cars of similar models.
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 02-18-2017, 09:03 PM   #4
glenB
Drives: Chevrolet Camaro SS
Here's the SS springs courtesy of Eibach
Non MRC
http://eibach.com/america/en/eibach-...s-2016-pro-kit
glenB is offline   Reply With Quote
Old 02-19-2017, 01:51 PM   #5
Snrub
Drives: Gone: 2017 Camaro SS
^ Interesting. Those are strange OEM spring rates, I never would have guessed those.
Snrub is offline   Reply With Quote
Old 02-19-2017, 04:40 PM   #6
glenB
Angles and position
Old 02-19-2017, 05:46 PM   #7
JaxChris
Drives: '16 2SS GD1 MX0 NPP F55 IO6
The front suspension on the 2016 has a lot of caster now.
Btw, Eibach should fix the typo on this line (there is an extra 2):
PRO-KIT rate 2: 121 N/mm (2691 lbs/in)
JaxChris is offline   Reply With Quote
Old 02-19-2017, 06:17 PM   #8
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
That is correct, that indicates the spring has two spring rates.
thescreensavers is offline   Reply With Quote
Old 02-19-2017, 10:59 PM   #9
tecmec
Drives: 2016 2SS
That's not correct. 121N/mm = 691lbs/in. There is an extra 2.
Old 02-20-2017, 10:23 AM   #10
F1FTY
Drives: 2018 ZL1
Good info, thank you. Two questions remain:
Rates for MRC FE3 (if there are any) and rates for MRC FE4
Nice to see factory springs are linear rate.
Old 02-23-2017, 08:33 AM   #11
Snrub
Regarding the rates, obviously angles and position matter greatly, but I can't recall seeing rates like that on any car. The caster is high, but not crazy compared to some other vehicles. The front rates are a little lower than I would have guessed, but not far away from typical. The rears are just weird.
Old 02-23-2017, 08:44 AM   #12
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Yeah - something is off on Eibach's site. Is N/mm right, or lb/in?
REAR
40 N/mm = 228.4 lb/in, not 121
121 N/mm = 690 lb/in, not 2691
I'm thinking that the correct rates are 40/228.4 and 121/690. This is obviously a progressive spring. Meant for comfort, not performance.
Also, I don't believe the stock spring is a straight 577 lb/in rate. It's probably progressive, too.
00 Trans Ram is offline   Reply With Quote
Old 03-29-2017, 05:15 PM   #13
F1FTY
Drives: 2018 ZL1
Bump up for 1LE rates
Old 03-29-2017, 05:20 PM   #14
F1FTY
Drives: 2018 ZL1
front
rear
1le springs rate
